0 Members and 1 Guest are viewing this topic. Read 11041 times.
It takes probably at least twice as long to get hot water to the spout as it does with a tank.
A tank or a tankless still has to travel the same length of pipe from where it is mounted to the water outlet that you are standing at waiting for the hot water. If that run is 75 feet, then you are going to have to wait for 75 feet of water to clear out the faucet for the hot water to get to you.
Do you really think a hot water heater has a tankless job? I know I appreciate what my hot heater does...
