Retrofitting Amps for Different Voltage
0 Members and 1 Guest are viewing this topic. Read 1035 times.
Haemus
« on: 4 Feb 2011, 03:26 pm »
Hi James,
It might have been discussed already (if so, please accept my apologies).
I came across seller of pre-owned Bryston amps claiming to offer if needed voltage change at factory (110V to 230V).
Do you offer such service at Bryston?
Greg
  • The Demo is Everything!
    • http://www.bryston.com
Re: Retrofitting Amps for Different Voltage
« Reply #1 on: 4 Feb 2011, 03:31 pm »
Hi Greg,
No sorry we do not - any thing like that is done by the distributor in the country it is going to and the warranty is reassigned and appropriate hydro stickers are applied.
james
