0 Members and 1 Guest are viewing this topic. Read 5509 times.
Not sure if this would work for you, but I would be inclined to move the sofa and side tables to the other side of the coffee table and put the media center/speakers on the wall where the sofa/side tables are now. With this arrangement you would solve the corner placement issue and improve imaging since there wouldn't be any side walls close to the speakers.
If this arrangement is not possible and you are limited to your existing arrangement, I would at least try to address the reflections coming off the wall to the side of the right speaker.
I'm sorry I don't have much input on your question but totaly unrelated, I think your schematic is prety slick. What program did you use to prepare it? Thanks, Garth
This kind of corner placement undoubtedly will affect any speaker's performance. It's not an optimal arrangement.
I have a pair of SongTowers QWT in a very large, open, untreated room with vaulted ceilings (peaks at about 20 feet) in part of the room. The room is about as large as yours and has large openings extending into other parts of the house. One of my SongTowers is about 3 feet from a corner with adjacent large glass windows and the other is near a doorway leading into another area of the house. Far from ideal, but my experience confirms the SongTowers are quite forgiving in placement. The highs, midrange and bass all sound very natural to me. I have received more compliments on the sound than any other speaker that I have owned, including some far more expensive.
I have read your informative and entertaining journey with the Salks and seen the handsome pics. I am ordering a pair of ST's. I also have corner placement about 10" from front wall and 6-12" from side wall..Are you happy that you ordered front ports?Dennis Murphy has a post where he liked the ST's at only 8" from front wall so that's interesting.But Jim suggested front ports to be safe, in case of mid-bass boom.. I feel it compromises the visual elegance a little, and with these speakers the looks are part of the appeal though not the main appeal.. I have heard the ST's at 12" from a wall, with one of them in a corner, and they were great, though too short a listen to be definitive.any feedback much appreciated, from your experience with placement in a less than ideal room.bestTOm
