Apc J 15 Power Conditioner W/bat. Back Up SOLD SOLD
0 Members and 1 Guest are viewing this topic. Read 807 times.
gnars
Apc J 15 Power Conditioner W/bat. Back Up Black Finish.
Battery date is 02-06-10
Comes With Full Warranty.
Asking 329.00 or best offer + shipping
Original Shipping Box, Packing & Manual JUST LIKE NEW
Specifications
Mfr Part Number: J15BLK
Output:
Output Power Capacity: 865 Watts / 1500 VA
Max Configurable Power: 865 Watts / 1500 VA
Nominal Output Voltage: 120V
Output Frequency (sync to mains): 47 ~ 63 Hz
Output Connections: 12x NEMA 5-15R
Waveform Type: Stepped approximation to a sinewave
Input:
Nominal Input Voltage: 120V
Input Frequency: 50/60 Hz +/- 3 Hz (auto sensing)
Input voltage range for main operations: 90 ~ 140V
Input Connections: IEC-320 C14
Maximum Input Current: 12A
Input Breaker Capacity: 15A
Batteries & Runtime
Battery Type: Maintenance-free sealed Lead-Acid battery with suspended electrolyte- leakproof
Typical recharge time: 16 hour(s)
Communications & Management
Control panel: Multi-function LCD status and control console
Audible Alarm: Alarm when on battery- distinctive low battery; alarm- configurable delays
Surge Protection and Filtering
Surge energy rating: 4500 Joules
Filtering: Full time multi-pole noise filtering, 0.7% IEEE surge let-through, zero clamping response time, meets UL 1449
Data Line Protection: RJ-11 Modem/Fax protection (four wire dual line),RJ45 10/100 Base-T Ethernet protection,Cable modem / Video protection,Co-axial Video / Cable protection,Coaxial 2-Way splitter with protection
Cord Length: 10 feet / 3.05 meters
Color: Black
Dimensions (WxDxH): 17.0 x 18.0 x 5.25 inch / 432 x 457 x 133 mm
Weight: 47 lbs / 21.36 kg
« Last Edit: 14 Feb 2011, 08:08 pm by gnars »
