Cornet2 capacitor questions
0 Members and 1 Guest are viewing this topic. Read 2515 times.
jdawg
« on: 3 Feb 2011, 03:13 pm »
I'm planning to build the Cornet2 kit and I'm in the process of looking up all the parts I need online.  I've already entered all the parts I need from digikey but the part numbers for capacitors C202 and C204 are no longer available.  What would be good replacement capacitors to use?
SC50
Re: Cornet2 capacitor questions
« Reply #1 on: 6 Feb 2011, 01:59 pm »
for Digikey go to Product Index>capacitors>film, then use the filters to narrow the field. Don't choose the parameters all at once. You might have to use a cap with different lead spacing, or use a 1 or 3% tolerence, so do those last.
WGH
« Reply #2 on: 6 Feb 2011, 02:36 pm »
What is your budget? The stock Cornet2 is pretty good, but with upgraded capacitors and matched resistors it comes close to to the best phono pre-amps available. My first suggestion would be to use "Search" and read every Cornet2 thread in the Hagerman Circle, that is what I did before I started.
The Cliffs Notes version:
C208 - Mundorf Silver/Oil bypassed with .1 uF Russian Teflon FT-3
C206/200 - Sonicap Gen 1
C203 - Sonicap Platinum
C202 - Sonicap Gen 1
C204 - Sonicap Gen 1
Wayne
poty
dangerbird
« Reply #4 on: 7 Feb 2011, 12:35 pm »
I would seriously consider WGH's recipe,  :thumb:,I did and I'm loving every minute.Good luck--let us know what you do.
jdawg
« Reply #5 on: 8 Feb 2011, 02:33 pm »
Thanks for the replies.  I decided to get some Sonicap Gen 1 capacitors for C202 and 204 because I think using higher quality capacitors for the RIAA circuit might be better.  I'm not going to change the other capacitors yet because I want to see how it sounds first.  Then I can upgrade later and see if more expensive capacitors really do make a difference.
