VMPS ----Wywires-----WOW!! What happens in VEGAS doesn't stay there...always.
0 Members and 1 Guest are viewing this topic. Read 3685 times.
John Casler
Many might have read about Alex, Mr Wywires, coming to my house just prior to THE Show in VEGAS.
We changed virtually every cable in my 2 channel system "except" for the digital cable (from transport to DAC) and the Power Cable from the Power Conditioner to the wall.
These replaced some rather expensive AudioQuest cables I have used for years.
For example the $3000 Volcano Speaker Cables.
All at the pre-Vegas GTG felt the Wywires made a nice improvement based on only a couple hours of A/B comparisons.
However when Alex left he only left the Speaker cables.
Just yesterday I received a box from Alex with three PowerCords, one having the 20amp IEC to run to the wall, and he also gave me a pair of XLR cables.
OK, too keep it simple, I listened to but a SINGLE Cut which I have heard hundreds of times both on my systems and on many others:
From DIANA KRALL - Album: The Girl in the Other Room
Stop This World
Krall's vocals, her Piano,  John Clayton's Bass, and the brushes on the drum kit, are all quite good on this cut.
So I pre-set the volume control to a good volume that was not too loud or soft, but that was sufficient to let me hear into the recording and sat in the listening chamber and pressed PLAY.
It, in fact sounded marvelous.  I listened for the subtlties like the brushes on the snare and the cymbals, the realness of the bass drum kick pedal, the tonal quality on the String Bass, and the attack, decay, imaging of Kralls Piano, and of course her sultry sexy voice.
I really can't say I found "ANY" weaknesses or faults to the sound.  In fact it sounded just as good as it always has, which is better than I have ever heard it on another system.
So, I now SWAP the AudioQuest PowerCords from the two Monoblocs and the PC from the PowerConditioner to the Wall.
So now every cable in the system (except the coax digital) is Wywires.
I press PLAY
 :o :o :o
While I am not a big CABLE GUY, I often suggest that my customers, clients and friends use a GOOD Quality cable with good metals and good connectors.  And while I have many times heard differences in cables, I don't feel mega-buck cables are generally needed if you pay attention to metal quality, and connector quality.
So what did I hear?
Well when I wrote about first hearing the VMPS RM50 in Vegas this year, I mentioned that it sounded "better" than last year, and that it had SUNDAY SOUND on Friday.
Well I am now sure that these cables may have played a role in that sound.
I was expecting subtle differences but didn't know what they might be.
Now what is subtle and what is HUGE is likely up for debate, but the more important point is, that I heard clear differences and they were improvements.
The first thing that CLEARLY Stood out was the drum kit.  Can't really explain it any other way except to say is was just more available and clear in detail and immediacy.
The brushes on the snare were so clear that I could hear the drum head reasonating, and the cymbals were just more metallic.  I could clearly hear the qualities of the materials rather than just snare and cymbals.  If you have ever played or stood by someone playing a drum kit with brushes, you know what I mean.
The Bass of John Clayton is always good and the difference here was that it was simply more tonally rich.  Overtones were a bit more present and decay was a bit more prominent.
Also, the Jazz Guitar which I heard on the first run through was also just more there, and supportive to the song.
While I really don't like how the Piano is miked and imaged (it is like I am sitting within a couple feet of it) the clairty of keystrikes and the decay of many of the notes was improved.
Kralls voice too was just a bit more full bodied and the raspy nuances and sultriness was thicker and more "there".
Am I floored?  NO, but now, I can say that Brian made a good choice when choosing Alex's cables for this years demo.
I like them so much that I am taking them on as a dealer and for those VMPS clients and customers looking for THE SHOW sound, we had in VEGAS these are one step in that direction.
wywires
John,
Thanks for writing up your initial impressions. Please be aware that the three PC's I sent you are NOT burned in on the cooker. In my experience with the Juice II, they need 40-50 hours to settle down. Initially they sound a bit thick in the lower midrange and upper bass as well as slightly muddy and chesty with certain vocals. This will improve over time. That being said, I think the II is a definite improvement over the original you heard in December even right out of the box.
eclein
Alex really has lightning in a " cable". I played drums far too long and hearing cymbals, drums etc. with Wywires installed was really the first time I can honestly say that the realness, the weight, the metallic sound that is percussion really came through.
werd
I was able to get a pair of rca's from Alex by invite right at the start. At that time his rca's were listed for around $1500 bucks for a mtr pair.  He took a lot of flak for that too  :icon_lol: At first i was a little apprehensive of the price. The night i put the rca's on, the thought of price  was lingering around in the back my head, "are these going to be worth $1500.00"?
I wasn't long into when it was apparent that i've never heard anything under $1000 that was this good. To ask for $1500 you would want personal attention and a personal thought out sound. Thats what i felt like i was getting from these. It was nowhere near  a generic sound  that can make you feel like you haven't got anything special.
Anyways the price is brought right down and makes these cables very easy to recommend. So go try some out....  :thumb:
John Casler
John,
Hi Alex,
Don't know about "muddy" since they didn't sound like it, but I now have over 40 hours on them and I did a quick run through with the same cut.
Clearly noticed something at the 2 minute mark and then again at the very end, that I hadn't noticed "clearly" before.
Wonder if anyone can pick up what it is?
From DIANA KRALL
Track #1 Stop This World
What happens at about 2:00?  and then changes at the end?
(and not that this is hidden but it is just more prominent when the cords are more burned in)
highfilter
I agree that the WyWires are truly fantastic cables. I recently just replaced all my cables in my 2ch system with WyWires and it has made a significant impact in advancing my system to be more organic, neutral, expansive and dynamic. I almost get a "wow" moment every night after work when I sit down and put on a track and something new pops out or is rendered more realistically than before.
I'll be writing my review on the cables and various changes on the older WyWires RCA/XLR cables and the newer type. Alex is on to something special! These Juice II cords sound yummy, I shall have to try them out as I have the Juice I models.  :D
wywires
Hi Alex,
From DIANA KRALL
I'll check it out this evening. I'll time the LP version with a watch and also try the CD and report back.
Alex
wywires
Hi Alex,
From DIANA KRALL
At 2:00 Peter Erskine switched from a brush in his right hand to a drumstick and then back to brushes in both hands the last 20 seconds or so. This is even more apparent on the LP where the sound of wood against the Zildjian high hat is very clear along with the characteristic Zildjian shimmer in every strike.
John Casler
DING DING DING :lol:
That is it, but I think it may actually be a nylon tipped wooden stick on the Ride Cymbal, it doesn't seem to have the slightly muted damping of a wood tip on the stick.  As well it doesn't sound like he simply turned the brushes around and used the metal handle.  If it is the High Hat, it is an "open" HH.
It sounds more like the sharpness/hardness of nylon.
But that is exactly what he does at 2:00ish into the cut.
Pretty incredible that you can hear such things (if in fact that is what is being heard)
All I can report is what it sounds like to me at this point in the burn in. :thumb:
John Casler
Must have well over 200 hours on the cables now and have noticed an increased sense of depth (3-D) and even more clairty (didn't think that possible)
It is so clear, that I can hear the drummer hitting the Ride Cymbal (my right/his left) and at around 2:50 he switches to a different cymbal (my center left/his center right)
Talk about ability to image and stage :thumb:
