0 Members and 1 Guest are viewing this topic. Read 4734 times.
Does this warm up count for tubes other than in an amp??? As I have tubes everywhere except in my amp... So, I turn on tubes in source, turn on pre (tubes), turn on SS amp. Everything engages after 45 secs to 1 min. I them stream ambient music at a low volume for 15 to 20 min before turning up and moving on... Also, If i am going to stop listening for a couple to few hours I will turn of the tube stage in the source off but sometimes leave the pre on.Am I practicing acceptable behavior?
My tube amp has a 45 second turn-on delay. I start listening right after that relay kicks. Sounds good cold and I know it will only sound better after a couple of tunes.
You know you can warm your tubes faster if you put a blanket over them....
You know you can warm your tubes faster if you put a blanket over them.... just kidding
Don't worry about warm up.Put on some tunes and enjoy the music.The longer it plays,the better it sounds(to me anyway).
