0 Members and 1 Guest are viewing this topic. Read 6111 times.
Richard,So much of what you hear (or don't hear) depends on the severity of your hearing loss. You may be lucky and have reasonably decent hearing above 8k. That is to say that even though your hearing is diminished, it may not be completely gone. If that is the case, you may well be able to pick up some of the highs above 8k. Granted they will likely be attenuated but you may well be able to hear them.You really won't know unless you have a professional perform a hearing test complete with FR graphs showing your hearing curve. Then you can make an educated guess as to whether you will hear the tweeter or not.Now this is just me and I have no firm info to back it up but I've always been suspect of some of the equipment they use in a hearing test. When you look at some of the high end headphones and compare them to (what seems like) the $1.98 pair of headphones they use for a hearing test, it makes me wonder just how accurate any hearing test may be. Sure, I may have it all wrong and those cheep looking headphones may be calibrated but .....
I find the idea of full range drivers interesting. Since two of these are made in Utah an easy days drive from my home (ZU & Tekton) ...
