New Saphire laid on side (center channel)
0 Members and 1 Guest are viewing this topic. Read 1792 times.
drcruz
« on: 31 Jan 2011, 03:04 am »
If I bought and laid down a new sapphire on it's side, could it work as a center, or is this a bad idea?
Mike Dzurko
Re: New Saphire laid on side (center channel)
« Reply #1 on: 31 Jan 2011, 03:31 pm »
A lot of people did exactly that with XLs. Sure, it is ideal to keep it vertical, but horizontal will work and keep a good tonal match with the mains. It will sound best when seated as close to directly in front as possible. The further you get off to the side, the greater the tonal imbalance will become.
drcruz
« Reply #2 on: 5 Feb 2011, 02:14 am »
Thanks Mike...   8)
