SW-12B Sub Woofer ==> cut-out dimension
0 Members and 1 Guest are viewing this topic. Read 1965 times.
wackii
« on: 29 Jan 2011, 08:01 am »
What is the cut-out dimension for this driver?  I'm thinking of building a sub or maybe two for the midbass (50hz - 150hz) range.  I'm wondering if this driver is suitable for this project.  I had an old cabinet enclosure that was used for a 12" driver.  I want to know the dimension and the cut-out hole size for this driver to make sure if it will fit in the box.  Also, in case if I want to counter sink the driver, what size hole should I cut?
Al,
Danny Richie
Re: SW-12B Sub Woofer ==> cut-out dimension
« Reply #1 on: 30 Jan 2011, 09:44 pm »
You will need an 11" through hole.
The outer gasket diameter is 12.625" and it takes .625" of depth to counter sink it.
wackii
« Reply #2 on: 31 Jan 2011, 09:52 am »
Thanks for the info.  Unfortunately, it doesn't fit on my cab :(
Al,
