2 SVS Ultras with 1000 Watt Samson Amp
0 Members and 1 Guest are viewing this topic. Read 869 times.
lowc
« on: 29 Jan 2011, 02:40 am »
Hi, just seeing if anyone out there is interested in 2 SVS Ultras with a Samson 1000 watt amp..if you like BASS, this is the set up for you..im located in California 95695 zip. Thanks
Asking $1,100 obo
Samson 500 watt per channel x2
2 SVS Ultras passive subwoofers
Specifications:
Driver: 12" Kevlar & Aluminum Cone
Power Handling: 500 Watts Each
Nominal Impedance: 4 Ohms
MFR: 16 Hz - 100 Hz
Size: 39" H x 16" Diameter
Weight: 72 Pounds each
Enclosure: Cylindrical Polymer Laminate; Birch End-Caps; Black Knit Sock Covering
Sorry, i dont have the original boxes so i dont want to ship if i dont have to. Will drive or meet half way if its not to far. Have the bass plugs for the subs and the owners manual for the amp. Thanks
-Pat
lowc
Re: 2 SVS Ultras with 1000 Watt Samson Amp
« Reply #1 on: 18 Mar 2011, 10:59 pm »
bump...
