b&0 turntabe, which is the 1 to have??
0 Members and 1 Guest are viewing this topic. Read 4384 times.
parr3n1
« on: 28 Jan 2011, 11:12 pm »
I am setting up a lofi system in my library and love the aesthetics of the b&o. Looking to make the right move so any input would be appreciated.
thanks
bunnyma357
Re: b&0 turntabe, which is the 1 to have??
« Reply #1 on: 28 Jan 2011, 11:44 pm »
I had a TX-2 which is one of the tangential tracking ones - it always sounded quite nice, and since it was automatic it helped keep all of my old vinyl in excellent shape.  There are 2 drawbacks, the hollow metal platter is fairly resonant. And they usually need B&O moving iron cartridges which have been out of production for a while.
Soundsmith is a source for B&O compatible stuff.
http://www.sound-smith.com/cartridges/indexBeo.html
I prefer the tangential tracking B&O's but the pivoting arm tables like the RX-2 are nice as well.
Jim C
S Clark
« Reply #2 on: 29 Jan 2011, 12:05 am »
If you get one, I have several B&O cartridges somewhere in drawers, a couple of which I remember as sounding pretty good.  So don't pass on one just because it lacks a cartridge.
orthobiz
« Reply #3 on: 29 Jan 2011, 12:17 am »
4002
Original ultimate in tangential cool
Paul
ssglx
« Reply #4 on: 29 Jan 2011, 12:29 am »
the 8002 is absolutely the one. The MMC2 is the cartridge to go with it.
I used them for many years. Missed it and have a TX linear tracking (belt drive) now.
rajacat
  • Washington State
« Reply #5 on: 29 Jan 2011, 12:46 am »
I don't know what's the best Beogram TT but I have one that's just taking up space.
 Beogram RX with the MMC4 cart. I'll give you a really good deal....I don't use it anymore. $35+ shipping. It's in very good shape. pm if interested.
-Roy
S Clark
« Reply #6 on: 29 Jan 2011, 01:04 am »
-Roy
That's a good deal- the cartridge alone is worth $35.
parr3n1
« Reply #7 on: 29 Jan 2011, 02:32 am »
rajacat, I sent you a private email, did you get it?
rajacat
  • Washington State
« Reply #8 on: 29 Jan 2011, 04:36 pm »
pm received
OzarkTom
« Reply #9 on: 30 Jan 2011, 04:16 am »
Back in the early 80's I used a beogram 1900 and always loved the sound. That table was originally made in 1976.
vinyl_guy
« Reply #10 on: 30 Jan 2011, 05:40 am »
I have a Beogram 2402 with a MMC-20EN cartridge. It's currently in my basement in the original box with the $325 price sticker from 1980. It gave me 26 years of musical enjoyment and I know it will spin vinyl again sometime in the future.
narkleptic
« Reply #11 on: 23 Feb 2011, 05:21 am »
I suppose that would depend on what you're looking for? Collectability? Reliability? Sonics? Looks?
Currently, I have a Beogram 4004 and a Beogram 5500 (part of a complete white 5500 system).
I have in the past owned an 8000, 8002, and 1800.
There's no question that B&O threw the whole weight of their engineering behind the linear trackers, and so these, for me are the most desirable, best built, and best-sounding tables.
I sure would love to have the original Beogram 4000, the first of the linear trackers. Never available in the States.
Next up is a toss-up between the 4002/4004 successors and the next generation 8000/8002.
Personally, I like the looks the looks of the 4000 series better, and I would rate the build quality a scotch higher than the 8000. Of course, the 8000 uses the nifty eddy drive system, and is a bit newer--though either one will require service if it hasn't had it already. If you get an 8000 series, get the later 8002, which will allow you to use the  MMC series cartridges.
After the 8000 series, the tables took a dramatic turn towards cost-cutting, easily noticed by the much lighter weight and correlating use of flimsy plastic. Still sound nice, and worth getting if you get a good deal that includes cartridge, but not on my list of "the one."
So the short answer, the "one" to have, IMHO would be your choice of:
1) Beogram 4000 series/Beogram 8002
It's a given that any B&O table requires the expensive and dicey vintage B&O carts, or the expensive and reliable Soundsmith alternatives. The thing is, those carts are really good, and of course, with the B&O, you're getting an integrated system, with the entire turntable, tonearm, and cart designed to work together...not so good for tweaky types to be sure.
