Reasonably Good Power Conditioner for $100 or Less
0 Members and 1 Guest are viewing this topic. Read 9950 times.
dBe
    • PI audio group, LLC
Re: Reasonably Good Power Conditioner for $100 or Less
« Reply #20 on: 29 Jan 2011, 05:13 pm »
Check out ps audio duet, lots of great reviews, well built, I have two.  Problem is they go FAST on audiogon, but if you are patient you can get one for around $100 - 125.  quintet has more outlets, 8 i think.  I also use porter ports.
+ , like 97 on these.  They work well.  Their MOV cartridge is quiet at least.   :)
Dave
Bugs
« Reply #21 on: 15 Feb 2011, 03:08 pm »
Anybody have any experience with this one, Blue Circle Audio PLC Thingee?  Still a hundred bucks over the $100 or les mark, but coming in  at a reasonsable $229 new.
Mass. Wine Guy
« Reply #22 on: 16 Feb 2011, 04:17 pm »
Do you think this Blue Circle Thingie is better than the PS Audio Duet? I just got a Duet.
doug s.
  • makin' music
« Reply #23 on: 16 Feb 2011, 06:22 pm »
i would recommend going to ebay and running a search on "isolation transformer".  many high quality medical-grade units come up, frequently for <$100, especially if you are patient.  also, i would recommend a separate unit for dac & transport; and then another one for the rest of your rig.  if you are really patient, you can sometimes find mondo units that will be large enough for an amp (rated 10a or more) for <$100.  but, these can get wery heavy, and shipping will sometimes equal the cost of the unit.  also the larger units, while wery good, can hum a bit; which may be a problem, depending on where you can put it...
here's some examples:
http://cgi.ebay.com/Xentek-Extreme-Isolation-Transformer-/150564136287
http://cgi.ebay.com/Dale-Tech-Medical-Grade-Isolation-Transformer-IT400E-/130487187731
http://cgi.ebay.com/ICS-Medical-T-600-Isolation-Transformer-/190502196707
http://cgi.ebay.com/Powervar-25-Isolation-Transformer-B250-22WISO-/190500400998
doug s.
