0 Members and 1 Guest are viewing this topic. Read 12694 times.
If you are going with the Aerial you need some high current amplification to make it sound alive. I heard it paired with a 150 watts per channel Rowland integrated in NYC and it sounded great. Regular Class A/AB power and no shallow D watts.
PS: no offense, but I can confidently state that all these speakers are light years beyond your Minuets in sonic quality.
I think those Arte Forma watts are class D, right?The issue with used sites, you buy, you usually keep them and if you do not like them, you sell them yourself. The people are not running a consignment or a used audio shop, they sell you at a discount and you take the risk for system matching.
And they (the subs) will relieve your Silverlines from trying to do too much (bass) which will improve their power handling abilities as well as midrange dynamics and clarity.
Stereo subs is the killer route. Note that bass is ideally generated in different places in the room than mids/highs. But if you (or wife) wants, you could use those cabinets as speaker stands (and be no worse off than simply using full range speakers).
In back is one balanced input and two unbalanced RCA plug inputs. Would I connect a pair of bare wires at the amp's speaker posts, and then terminate the other two ends with RCAs?
