Bridging D200 Mk I
0 Members and 1 Guest are viewing this topic. Read 1811 times.
ua100k
    • Merrill Audio
Bridging D200 Mk I
« on: 28 Jan 2011, 12:02 am »
Hi Dusty,
Can I bridge 2 of original D200 Mk I - using inverted input to one and non-inverting to the other. On the outputs, positive to negative tied and then using the positive on one unit with the negative on the other unit going to the speakers?
Thanks.
CIAudio
Re: Bridging D200 Mk I
« Reply #1 on: 28 Jan 2011, 05:13 am »
It's not as simple as you described but could be done by adding a small value cap across the output to sync. their switching frequencies.
You can email me if you want further info.
[email protected]
