0 Members and 1 Guest are viewing this topic. Read 5457 times.
This topic makes me wonder, is it the passive crossover that full range guys hate? Or is it the woofer, mid, and tweet? Why is it that one would ditch oNe set of problems for (forgive me I mean no harm) a set of much worse ones? I really am curious why true FR guys do it the way they do?I for one also do not like the sound of passive crossovers, but I went active 1st orders and SET with huge dynamics, tight bass and crystalline highs. Something that I have not heard from any system with a passive crossover and certainly not something I've ever heard from FR of any sort. Though I personally think passive comes closer than FR. Am i missing the point? Any feedback would be greatly appreciated.
<snip>The only time I ever really had a higher appreciation for any of these configs is at RMAF when I heard the Lowther fullrange at RMAF 2 years ago. Problem is, it was augmented by 8" woofers.
Jason,I assume you are talking about the Lotus speakers. If so, they used a pair of 15"ers to augment the bass of the Lowther rather than the 8s you mentioned. I'm not so sure it is a "problem" unless you approach the FR/WB driver from a purist point of view. The upper end Lowther drivers (PM2A, PM5A) actually extend out to about 12-14k with fairly even treble. Enough so that you really don't need a tweeter. The great part of that frequency response is that they don't sound dull or colored like a few other FR/WB drivers out there.The big drawback to Lowthers is their lack of bass. I've played them in OBs, back loaded horns and bass reflex enclosures. None of those delivered what I would consider quality bass. In turn a few of us have decided to augment our Lowthers with big woofers to fill in the bottom end. In my case it's a pair of 15s in BR enclosures. I'm pretty sure you listened to Jon VerHalen's (Lowther America) version of my speakers at last falls RMAF. He finally switched over to a BR enclosure after many years of prodding. Using the PM2A on an open baffle above and a 15 below, you can create stunning sound by biamping and using an inexpensive active crossover. Heck, you could even do a passive XO at say 150-200Hz and make it sound pretty darned good.The issue I have with the Lotus design (besides the ridiculous $120k price) is that they use digital EQing to achieve a flat response. That and I don't know if you noticed, they also use a helper tweeter on the back side of the baffle.Now, digital EQing is fine (honest) but when a typical speaker designer approaches a new design, they want to achieve the flattest response they can without resorting to an EQ or heavy notch filters in the crossover. This is the way I approached my Lowther design. I use no EQing or filters of any sort. I simply use an active crossover rather than a passive. And honestly, I don't need any EQing. I get a pretty darned even response up and down the frequency chart. Sure, I don't get much above 14k but that's OK.As JLM mentioned, it's all about coherency but I'll take it one step further. It's also about having no passive parts downstream of your amp. Passive crossovers suck the life out of music. Once you hear a WB driver done right, you will fully understand. Until then you can only hope for a minimally invasive sound from your passive XO.IMO (and it is just that), I'm not sure we will see a true FR driver that can do say 40Hz to 15k (well) anytime in the near future. Most that come close are either (like the Lowthers) bass shy or colored (Fostex). Who knows though.The one thing about my OB design, you need a big room to support them. They really like being 6+ feet out from the wall. Those monster woofs don't take kindly to small rooms either.Ultimately, for about $5k you can do a complete build similar to what I've got. Use the 15" Servo sub. a pair of PM2As, buy a vintage analog XO and build an enclosure. In the grand scheme of things, that's not so bad. You can use anything from a 45 or 10Y SET on the top side to a Krell on the woofers. You have lots of options and all of them can sound stunning, far better than traditional monkey coffins (IMO of course).
Check out Fostex F200A drivers, definitely not your typical Fostex driver. Medium efficiency, but rated 30 - 20,000 Hz at 8 ohms with the magic of AlNiCo.
Who knows, maybe someday soon we'll get there (30-20k) without giving up too much...
