0 Members and 1 Guest are viewing this topic. Read 10367 times.
I've been reading about those, might have to try them on my VR-2s...did you try them on your amp too? From what I have read that is worthwhile also.
Go for it, they have a money back guarantee.
You know I like Mesquite Great lookin table.
It is hard to believe but 15 months have gone by since my last mod, I must be running out of things to do to this speaker. Those of you not following along can start at Part 3 and work backwards.The EVS Ground Enhancers are more of a tweak than a mod but the results are just as dramatic as anything I have previously done to the VR-2's. As you can see in the photo, the ground enhancer is a white pig tail that is attached to the ground. Just how they work is anybody's guess, but they do wonders to the sound.I have been listening to the EVS Ground Enhancers for a couple of weeks and am amazed at what they can do. Ordering was easy, first I sent Ric 35 PayPal dollars, received a reply the same day and my enhancers were shipped the next day.My system includes the Von Schweikert VR2 speakers and all Van Alstine Insight+ electronics, this combination responded very well with the enhancers installed. I didn't notice any break in period, the sound and presentation changed immediatly and I have not noticed any change since. The enhancers made quite a few changes to the character of the sound.The most noticeable change is greater separation. Instruments and voices are more delineated in space. Music that seemed to be clumped between the speakers is now spread out: left, right, and center with individual musicians easier to pick out. With a wider sound stage there is also more depth, the area between the speakers opens up quite nicely. The Miles_Gurtu album has a lot going on, the enhancers turn the album into an aural 3 ring circus.Some people have mentioned more bass or treble, I did not notice an increase at either end. Listening to music from an adjoining room the stereo sounds exactly the same as before. What I have noticed is a faster attack and greater clarity in the treble which gives the impression of an increase in high frequencies. The VR2's tend toward a warm presentation, the enhancers bring the sound closer to a neutral presentation. I first noticed this effect while listening to Tom Petty's latest album Mojo. Tom's voice is not as sonorous with the enhancers in place. The flip side is that vocals are now more intelligible with enhancers. My stereo is also part of a 4.1 surround system used for movies and television. Voices from the phantom center channel are now better defined and easier to understand; movie sound effects have more punch too.The EVS Ground Enhancers are quite an amazing tweak, it is like getting an electronics upgrade for almost free. The + upgrade for my AVA pre-amp cost more and didn't do as much for the sound as these little white pig tails.Highly Recommended More information with reviews are in an Industry Ads thread:Introducing the mind blowing EVS Ground Enhancers!The technical side of the ground enhancers are explored in the Lab:The BudP DIY Speaker Ground TweakI can do A-B demos in less than a second for the doubtful.Wayne
I settled on my wiring scheme when I still had my JBL L100's set up, even though the JBL's have a 12" woofer they still need a lot of juice to get good bass. My electronics are in an adjoining room and I felt the 25' of Kimber VS was attenuating the bass so I added some affordable MonoPrice cable and the low end filled out nicely. The MonoPrice cable by itself slightly rolls off the highs. The VR-2's also sound better with both cables.Wayne
Reduced resistance (heavier gauge or by-wiring) is another factor that contributes to a change in sound that most attribute to bi-wiring.
