Does Quicktime give bit perfect output?
0 Members and 1 Guest are viewing this topic. Read 1119 times.
gdg
« on: 26 Jan 2011, 04:54 am »
I'm wanting to use my computer to play a dvds that have a  dedicated 24/48  PCM audio track and feed the optical out into a high end pro audio setup (Genelec). Will Quicktime give me a bit perfect optical output?
skunark
Re: Does Quicktime give bit perfect output?
« Reply #1 on: 27 Jan 2011, 03:47 am »
Benchmark has a guide to configure your mac to be bit perfect.
http://www.benchmarkmedia.com/wiki/index.php/OS_X_Audio_Playback_-_Setup_Guide
gdg
« Reply #2 on: 27 Jan 2011, 04:30 am »
Thanx,
I set this all up when I started using iTunes and had made the appropriate changes to match the dvd sample rate and bit depth when I played the disc from Quicktime. I just wasn't sure if Quicktime did anything else (like compression) that might reduce sound quality.
