Piccolo Impedance Switch
0 Members and 1 Guest are viewing this topic. Read 1414 times.
eparson
« on: 24 Jan 2011, 03:50 am »
I just finished my Piccolo and it fired up and worked right from the start without any issues.  The Phono Preamp that I have it connected to (Decware) has a much greater range switch for impedance matching than the Piccolo.  So the question is, is there anyway to disable the impedance matching switch on the Piccolo?  Thanks   :scratch:
everett
poty
Re: Piccolo Impedance Switch
« Reply #1 on: 24 Jan 2011, 09:12 am »
The Piccolo is "one way" device. It is not translating your Decware settings to its input. So the right way to use the Piccolo and Decware together is using impedance selector of Piccolo and set the Decware's to 47k.
I think if you have only MC (low) cartridge - you may change the impedance resistors in Piccolo just to cover the useful range (originally the resistors range is universal - from MC-low to MM).
