Other Stuff
Archived Manufacturer Circles
Hagerman Technology
hagtech
ST/coke bootle rectifier in Cornet II
0 Members and 1 Guest are viewing this topic. Read 2019 times.
Grinnell
23 Jan 2011, 06:47 pm »
Anyone using one of these in the Cornet II? Will it fit okay? seems like the clearence to the transformer (YMMV) is tight.
How wide are these things?
karl
dangerbird
Re: ST/coke bootle rectifier in Cornet II
23 Jan 2011, 10:53 pm »
dunno,, suppose you could try it and see,, I can't get a Mullard 5AR4 in my cornet,,the base is a tad too large.
GRD
Reply #2 on:
23 Jan 2011, 11:51 pm »
5V4G is 1 and 13/16 inches in diameter (slightly less than 2 inches) at the widest part.
amandarae
Reply #3 on:
24 Jan 2011, 05:34 am »
I been using Mazda, RCA(Radiotron/Cunningham),Crosley, National Union, Tungsol, etc. on my Cornet II for three years(or more!) now, no problems. All of them ST type.
If the Mullard 5AR4/GZ34 does not fit on the Cornet II rectifier position (the original chassis cut out hole), then what you have is a fat bottle type. I have the same experienced, but the regular Telefunken, Mullard, and Amperex Bugle Boy GZ34' do fit.
poty
Reply #4 on:
24 Jan 2011, 08:44 am »
According to the drilling guide the distance between the transformer and the rectifier's hole center is around 0.96" (24.5mm) (the transformer's cover is 0.53" from the holes). If we assume around 1/5" (5mm) clearance between the transformer and the tube we can easily count the max tube bulb:
(0.96 - 0.2)*2= 1.52" (39mm)
dangerbird
Reply #5 on:
24 Jan 2011, 12:09 pm »
thank you amandrae--guess I'll continue the search for a standard size 5AR4.
Thanks for posting that.
amandarae
Reply #6 on:
26 Jan 2011, 06:19 am »
Welcome!
Other Stuff
Hagerman Technology
hagtech
