Decided On A New Phono Stage...Goodbye Hagerman....Hello Liberty Audio
0 Members and 1 Guest are viewing this topic. Read 13722 times.
Mister Pig
  • "when pigs fly"
    • Affordable Audio/Positive Feedback Online writer
My previous phono stage was a Hagerman Coronet II with some parts upgrades. A nice tube phono stage, but it needs a step up transformer to run LOMC carts. Also I found the tonal balance not to be as even as I would have liked, although it was pleasant to listen to.
I decided I wanted a SS phono stage, and I did listen to one of the battery powered ones out there. But in the end I am buying a Liberty Audio B2B-1 phono stage. Liberty is actually a factory direct line of PBN Audio.
Whats interesting is the B2B-1 is the same basic circuit as the two PBN phono stages. But the unit is stripped down, after all the two PBN phono stages are significantly more expensive than this one. This is a dual mono design, which includes two torrodial transformers in the power supply. Also a direct coupled output stage, and makes liberal use of JFETS throughout the circuit.
Tonally the B2B-1 is remarkably even, and the noise floor is extremely low. Great low level detail, and excellent layering to the sound stage. Capable of recreating large dynamic swings, but also does the low level dynamic contrasts very nicely also. While it doesn't possess tube warmth, I really don't believe this piece has any significant flaws.
This one is a keeper, and sets the foundation for analog playback in my system.
Couple of interesting things. The entire thing is built of domestic parts, except for the circuit boards. The B2B-1 is assembled completely at PBN. Even the case is is one piece of metal that is folded and welded in all four corners. Of course the top plate bolts on. Makes the Hagerman chassis look like a piece of junk, but its just a basic Hammond chassis. While a deceptively simple looking component, the thing is really put together well.
Regards
Mister Pig
WGH
A more in depth review is at Positive Feedback
http://www.positive-feedback.com/Issue52/liberty.htm
Looks like people now have 3 good choices for an affordable phono pre-amp and for a reviewer the Liberty makes perfect sense. The Cornet2 does have a nice glow which makes listening a pleasure, adding the Russian FT-3 bypass caps adds a bit of sparkle and dynamics the original design lacks.
Great review BTW.
Wayne
neobop
  • BIRD LIVES
Interesting review. I don't own either of these units so I have no ax to grind. But, I must say, according to the review contents the Nighthawk seems like a much better value at less than 1/2 the price. It also doesn't have the lower midrange leanness. This wouldn't appeal to a lot of people. Losing a little front to back wouldn't bother me much, I don't think. The vocal used for audition projected around 3' in front of the spks rather than 6' ? I rarely listen to vocals anyway, but it probably applies to any solo.
Of course, this is entirely based on another persons ears and equipment. I imagine that writing a review like this it's difficult to impart the entire gestalt of the experience. Maybe the Liberty was significantly cleaner or more detailed or the dynamic impact thing made it stand out in a much more dramatic way then what I got from the review. It seemed to me that the Liberty has a little more gain for a cart with a .2mV output. IMO that could explain both the dynamics and front to back superiority. The fact that the reviewer used a substitute arm, was suspicious.
neo
BaMorin
  • AR turntable rebuilder/modifyer
Just curious in my question(s)........these phono only preamps......how does the evaluation of them not actually include the final output of the preamp they're plugged into?  These are not driving the amp(s)
neobop
  • BIRD LIVES
It doesn't. Other equipment is normally listed (which it was). Synergy is often discussed. YMMV
neo
Mister Pig
  • "when pigs fly"
Actually my system is somewhat unusual in its ability to evaluate phono stages. The pre amp is transformer based, using nickle core transformers for a small amount of gain and impedance buffering.
The power amp is a 300B SET amp, but uses a pair of op amps as the pre driver stage. The amp is intended to be driven off a fairly low input signal, so it does not heed a fully active pre amp to function properly.
So in essence the phono stages are driving the power amp, the pre amp has a minimal influence on the voicing of the system. So making a comparison of these phono stages is feasible.
Regards
Mister Pig
Mister Pig
  • "when pigs fly"
neo
Never intended to have the review dug up, but it is mine. I have been an AC member, and member of AA and AK before I joined PFO. I still like to participate in the boards, and see what others have to say. I always thought my involvement in A$$A and PFO shouldn't preclude me enjoying my forums. But I supposed there can be some difficulties.
Sure the Nighthawk and the Liberty are different, and as you point out personal preference is going to determine what is and is not valued by a listener.
I personally like the space/layering/soundstage the Liberty offers, and its ability to resolve detail without being analytical. Also the bass response is stupendous, its quite amazing what it does in this regards.
The Nighthawk is a fine stage also, and one of the better buys at the less than 1K price point. One thing I find interesting about it is this. The top two gain settings offer the most space, low level resolution, and transparency. The other settings tend to make things too laid back and romantic for my taste. If I heard it at those settings, I would think its a ho hum piece. At the top two settings, well its extremely satisfying.
The Audio Artisan arm is a loaner, while I wait for a Pete Riggle String Theory arm to be finished. Here is a link to the prototype, there is a lot of well thought out engineering going into this one.
http://jeffsplace.me/wordpress/?p=838
But the same arm and cart were used to evaluate all the phono stages, and the arm with a Discovery arm cable outperformed a modded Incognito Rega, so its a respectable piece. For what its worth, I actually managed to find an Accuphase AC3 and ran it in place of the AC1 the review was done with. The Liberty matched up better with the AC3. Had to bump up the impedance, but its  a nice combination. So the AC3 is staying, although I am waiting for a Denon 103 in Uwe ebony body to be sent back from Sound Smith. Its getting the ruby cantilever and optimized line contact stylus rebuild. Some circles in the analog world think this is a high performance cartridge in spite of its price.
Just thought I would share my elation with a good phono stage on the boards I frequent, more as a hobbyist than anything else. Heck I spent my own money on the thing, and small companies don't give these things away. Actually this is one of my favorite audio purchases of last year, but it seems easier to spend money on analog than anything else LOL.
Regards
Mister Pig
neobop
  • BIRD LIVES
I appreciate your thoughts about this phono stage. I really don't keep up any more with what's available, or the latest and greatest. The parent company  certainly has a couple of pricey models. $20K phono stage?
The Liberty looks like a lot of discreet parts with one IC on each gain stage per channel (4 total). If the top PBN has a separate power supply and all exotic parts, I guess you could justify that price tag. My experience with high end components would indicate that price is based primarily on perceived relative performance, and cost often has little to do with it.
Your phono cart certainly got my interest. The Accuphase carts were my favorites back then. I now use a Genesis 1000 (among others), also made by Nakatsuka, with the same .2mV output.
"The Nighthawk is a fine stage also, and one of the better buys at the less than 1K price point. One thing I find interesting about it is this. The top two gain settings offer the most space, low level resolution, and transparency. The other settings tend to make things too laid back and romantic for my taste. If I heard it at those settings, I would think its a ho hum piece. At the top two settings, well its extremely satisfying."
I can't help but to think this would be applicable with any phono stage amplifying a .2mV cart. I use more than 60dB of gain with my Genesis. Any less, and low level res etc starts to drop out.
Let us know how you make out with your 103. I'm going to take a look at that arm you linked to. I don't know reactions at AA and AK, but I for one, say keep em coming.
neo
BTW, Got a link for Liberty?
Mister Pig
  • "when pigs fly"
neo
Here is where I originally was exposed to the Liberty. They appear to have kept things pretty low key, and do almost no promotion. I understand from Peter Noerbaek that there is going to be a Liberty power/pre combo to be released soon. Know almost nothing about it except that the amps are supposed to be a Mosfet monoblock design.
http://show.audiogon.com/cgi-bin/st.pl?preaphon&1278103758&item&Libertyaudio&4&5&6&http://cgi.audiogon.com/cgi-bin/srch_fs.plQQANYAAKEYWAApurlsrchAAEXYAAstAAAAliberty+audio
Couldn't debate with you about the cost of the PBN products, they hold little interest for me. I am just a regular guy, and my interest is in the type of components that the everyday person can afford. So I try to find stuff that offers the best performance vs cost ratio.
For instance I found that the King Rex electronics offered a great value, and would be an awesome way for someone to get into hifi on the cheap. But of the three pieces, the pre amp is the real winner, and could be used in a far more sophisticated system than one might imagine. And its only three hundred some bucks.
Sure the gain structure required by the Accuphase may favor the Liberty over the Nighthawk. Also the lower gain settings on the Nighthawk may be better suited to a HO moving coil. Never been a big fan of HOMC, as past experience with them showed most cartridges to have to much character for what I want. Possibly due to the additional windings and changed magnet structure to obtain that increased gain.
As I recall I had the Nighthawk around when the Ortofon Cadenza Bronze showed up, and I still found it best at the higher settings. Course I hadn't explored this thought with much focus then, and the Ortofon is no longer here. Will look into this when I have a higher output MC around again.
From my perspective reading reviews is another persons take on a component. The review is dependent on the associated equipment, room, and writers personal preferences. This stuff really can't be considered gospel, but more of an informed discourse on a component. It gives a person an auditory snap shot of what another person experiences. Associated equipment and listener needs may or may not jive well with what the writer was using, so everyone needs to think for themselves too when it comes to the buying decision.
Regards
Mister Pig
neobop
  • BIRD LIVES
Thought I'd post this link:
http://www.kingrex.com/product.aspx
A quick Google search showed your review and a couple of others. Also saw a thread at AK or AA on these components. For me, someone who makes little attempt at keeping up, reviews like this are of great value. Good to know what's out there.
neo
Mister Pig
  • "when pigs fly"
Hi Neo,
Was curious to know if you ever followed the link to the Pete Riggle String Theory arm. There has been a change or two to the design. The most notable being that an under slung counterweight has been added to the design, which provides a greater degree of stability at the unipivot.
The one thing that is unusual about the arm is the anti skate function, and I am not sure about they way it is executed. The anti skate force is provides by a slight twisting of the four mono filament leads that make up the bearing. Not a common way to do this, although the Well Tempered arm also has an unusual anti skate device also, at one time it was related to the base that was hung in the silicone bath. There was no adjusting that set up, this one has some degree of user control. One thing about the 12 inch arm is that theoretically anti skate is less of an issue with these longer arms. As I recall, there is more than one arm out there that does not use an anti skate device, so while they are common,,,they are not universally accepted as necessary.  Pete is a practical type of engineer, so I am willing to keep an open mind and see how the thing works out.
If I don't do the String Theory arm, I also thought about looking at the MG1 linear tracker from Advanced Analog. That looks to be another high performance type arm without the astronomical price tag. My previous arm was a ETII, so I do have a preference for air bearing arms.
I recently let go of a Townshend Rock table, on which I had a rewired Rega 251 on it with counterweight and VTAF accessories added. I don't really cotton to the modified Regas, so I let mine go. Finding the tone arm that I want for my Serac is not as easy a task as I had hoped.
Regards
Mister Pig
WGH
I'm still a happy user of a KingRex pre-amp. Here is my review:
http://www.audiocircle.com/index.php?topic=68537.0
Wayne
Mister Pig
  • "when pigs fly"
Wayne
Interesting post Wayne, I enjoyed reading it. I found the King Rex pre amp to be an outstanding piece. Actually it has a ton of potential, and if anyone is working on a tight budget, I would be hard pressed recommending they spend more money on the pre. Get the King Rex and spend the funds saved on a source or speaker upgrade. Get a high efficiency speaker and one of the King Rex power amps with standalone power supply, and you are going to get crazy sound for the money.
You know one weekend I bi amped a pair of speakers with a 2a3 SET on the top end and the King Rex integrated on the bass, both controlled by the King Rex pre amp. That was a sweet little combo, and sounded far better than one would expect. I could see a bi or tri amped chip combo being a killer set up.
Regards
Mister Pig
neobop
  • BIRD LIVES
Hi Neo,
Regards
Mister Pig
Yea, I took a look at it. Pete's a nice guy and I wish him luck. I'll reserve judgement till I actually hear it or until the most everybody says it's the best thing since sliced bread. I tried to look past the beauty shots to see how it works, but I don't have a clear idea about that. Maybe I'll check out his site.
Now he has azimuth on the fly? I must say I love VTA OTF, but the mechanisms that make it possible almost always go against my understanding of how to do it right. I'm more into the Pierre Lurne school of TT/arm design:
"Along with Pure Mass, the K.I.S.S. (Keep It Simple Stupid!) principle is fundamental to the design of the arm. Every joint, every bolt, every thread in an arm acts as a reflective surface to vibrations, causing colouration and reduced dynamics. In designing the Septum, Pierre Lurne has eliminated all unnecessary components. Uniquely for a unipivot, the single-piece, tapered-aluminium armtube/headshell assembly is machined from a solid, drawn bar. The unipivot removes the need for bearing races and their mass of contact points and bearing chatter. Finally, though Septum has all the usual adjustments available, such as arm-height and alignment, all the structures needed for this can be removed once optimum settings are found. No unstable VTA towers with their mass of threads and compromised rigidity, once adjusted Septum reverts to the most elegant structure possible.
This simple structure allows the cleanest path for vibrations to escape. Being machined from a drawn bar forces the crystal structure of the metal to align along the length of the armtube, the result is that vibrations from the cartridge will tend to pass along the armtube rather than bounce within. This energy escapes via the single pivot point to the high-mass, damped subchassis, or to the heavy, soft-metal counterweight, where much is absorbed rather than reflected. Simple."
That said, I almost bought a VTAF for my Sonus unipivot. I was afraid that the total weight was too light, but I was going to try it anyway. Then the ground wire came loose inside the pillar so I had to re-think the whole thing. It might be a better idea to get one for the Alphason instead. I'd be better able to evaluate it and it's probably a better candidate. Anyway, I have severe reservations at this point about the string-arm, but it's an uneducated guess. I don't like the looks but if it sounds good....
A Gyrodec/ ET2 was part of one of the best systems I ever heard. Around 1990. This Dr had a Spectral pre, big Roland monos, a 30w Berning, 2 lg Entecs. Roland was driving 2 panel Acoustats (side by side panels), with Emit tweeters between the panels for > 5KHz. The Acoustats were driven full range in the bass and the Entecs were EQ'ed with an Audio Control Richter Scale III. That's 5 band EQ for the bass with calibrated mic and test tones. He had the room worked out too. It was astounding, real sounding. We only listened to the record player. Back then CDs weren't listenable on a really good system. For the life of me I can't remember what cart he was using at the time. I remember him trying different MCs, maybe a Miyabi, VDH or an AC2.
There were a couple of threads here about some linear trackers a few months ago. I remember some discussion about eff mass. You ought to search them out. The MG1 was discussed. A couple members here have one.
neo
djbnh
I use the Riggle VTA, works as advertised. YMMV
neobop
  • BIRD LIVES
DJ,
I have no doubt about that, it's why I'm still considering it. But I think its successful use depends on having weight to the arm. It just seems that way to me, looking at the design. I think the whole thing would be compromised without some weight. It was developed for the Rega. That Sonus arm is one of the lightest I've seen. I've been thinking of pulling the wires from inside the arm and wiring it externally. Then I could fill up the arm tube with expanding foam for rigidity, and fill the pillar with lead.
neo
BaMorin
DJ,
neo
Neo, if the pillar is hollow, and will allow the retention of fluid, use lead shot and silicone oil. The silicone will turn all stray vibrations into heat instead of noise. The shot will act like a bunch of individual boundry layers.  Nothing damps vibration like a sand bag or a bag of shot.
Mister Pig
  • "when pigs fly"
neo
Very valid points of course. For me the String Theory arm is an experiment, and the initial reports from the prototypes look to be positive. But still its a venture into uncharted waters, that cannot be denied.
For what its worth, when I make a purchase I often try to shop the designer/company as well as the product. This might be an example to clarify what I mean.
When I decided I wanted to return to SET amplification I called up Jack Elliano. I said Jack I need an amp and PVA pre-amp, you got anything for me? I know what Jack does, how he thinks, and I understand his products. So I place a great deal of trust in Jack, and the amp/pre combo he sent out to me is wonderful.
When I bought my table, I knew Thom Mackris, although not as well as Jack. I remember Thoms passion for analog when I met him at VSAC. At that time he was involved in Redpoint Audio, and their products were extremely good. Now I prefer high mass/unsuspended designs, which is what Thom designs. So I called up Thom, and once again placed a great deal of trust in the person....and took the product recommendation. Once again I have not been dissapointed, and the table is exactly what I was looking for.
I know Pete very well, actually I live about twenty minutes from him. Have been over to his place many times to listen to music. We have a small audio group here that has a few writers from 6 moons/PFO and Kara Chaffee makes it up a couple of times a year for gatherings. But anyways, I know Pete, and what he values, and how he designs things. So I am buying Pete and his talent, and trying to be unbiased regards to what I think I like. I like linear tracking air bearing arms, so I am uncertain that I will be completely satisfied with this 12 inch pivoting arm. But I have enough confidence to give it a go. After all audio is a journey, and I am interested to see what part of the path this way carries me. I can always find another ET II and refurbish it, Bruce Thigpin still stocks parts for it.
The String Theory arm is fairly simple in its layout. There are four monofiliment lines that gather under the top knob. They are tensioned by the knob for anti skate force. They come to a single point on the arm body. Under the arm body is a small cup that allows for oil dampening. There is a pin that rides in the oil. A snubber slides over and contacts the pin and makes the initial adjustment for balancing the arm. Since its a unipivot of sorts, then the side weights are adjusted to get the final setting. The arm body is wood, and fittings are brass. Now with brass fittings its a 30 gram effective mass, if you use the optional aluminum it becomes a 15 gram arm. Yes it uses a VTAF, which works quite well. Once again a simple yet effective solution.
But the VTAF is based on the idea that you want to uncouple the arm from the table. This works on the applied principals that people developed setting up the Rega. Basically that the lighter the tightening of the arm nut on the arm pillar(old style arm) the better the sound. So Pete took it one step further and completely uncoupled it. This works for Rega arms, but its acceptance is not universal...which it true with all audio stuff. However with other arms, I am not sure this is the case. I think it goes on a case by case basis myself. I think Pete believes in the universality of the concept. Since it cannot be tried on every arm on the market, the buyer needs to be willing to exert some effort and know it may not work out in the end. However, I think Pete does offer to trial the VTAF in these situations. But don't take my word for that alone!
Analog is an interesting endeavor. There are so many pathways to spinning a record, and each one offers different sites along the way. I love hearing them all.
Regards
Mister Pig
neobop
  • BIRD LIVES
I'm a little mystified that there's no mention of the arm on Pete's site. Maybe I missed it somehow, but it was all VTAF. WTF? If you didn't link to Jeff's Place..... Considering that the first 10 customers got it at 1/2 price and price goes up in increments till 30 are sold, it just seems stupid not to be on his own site. $1600 isn't all that much for an arm these days, but considering it looks like hardware store fittings and a wood shop arm tube held together with fishing line, perceived value might be a problem.
I'm not buying one anyway. My biz got busted with the economy and I'm selling. It just seems like crazy marketing. Are there ads in the mags? LOL, I don't read them either. There was something in the Asylum, like his own circle.
I think you should try a 10" brass one for the 103. Save the Accuphase for the air bearing. 250mm eff length is enough to minimize tracking error and there will be less of a lag between stylus and bearings, or strings as the case may be. I'm making fun but the arm might sound good.
As far as the VTAF goes, I think it can only work well with arms of  considerable mass. The mass of the pillar and counterweight will absorb the vibrations. Otherwise mass coupling is mandatory. It's one thing to improve a Rega, a whole cottage industry has evolved for that, but that doesn't mean it's universal.
neo
Mister Pig
  • "when pigs fly"
neo
Hi Neo,
Once again valid points that have merit. But I wasn't ever trying to get you on board to buying one, or even validating a purchase. It's my job(err you could call it that) to find stuff that is affordable and offers great performance....which equals value to the everyday audio person. Actually even 1.6K is a good deal of money, although in the tone arm world everything is expensive these days. Lots has changed since the advent of CD, vinyl has become a niche type market with escalating price structure. Very few things in vinyl are affordable anymore, but yes some still exist.
I can see your perspective on materials/assembly, and it does make sense. But you know there has been a few movements in audio that have started and endured, and offer the potential for excellent sound, which used materials/construction techniques that ran against the accepted thinking of the audio world. The whole high efficiency single driver speaker movement is probably the best example. One could say what kind of sense does it make to build a whole speaker around a $30 or $60 apiece Fostex driver? Why sink hundreds if not thousands into these complex cabinets for a cheap speaker? Yet there have been many great sounding systems built around this type of speaker. Or the chip amp movement. The guys who run beefy SS amps were probably taken aback when these types of amp left the realm of inexpensive, and manufacturers started offering these products in the kilobuck range. The price of these output chips certainly don't justify the cost of some of these amps. But once again good sound has been achieved.
So in my case I am willing to extend some trust to Pete, and see what this arm is all about. There are very few products on the affordable side of the audio spectrum that are distinctive and offer the possibility of great sound. I am willing to spend some time and look for them.
AS far as using monofiliment for a bearing, its not an unique concept as you know. Well Tempered has done it, and to some extent the Transcriptor Vestigal had a monofiliment element to its design. Basically the String Theory is a new interpertation on work that has been done before. Which is a recurring theme of audio in general.
I don't think the String Theory arm is going to ever be heavily advertised. I believe Pete is using word of mouth to do a soft start on the product. As I recall he is still working out logistics for materials, getting an efficient building process streamlined, and trying to determine how many he can effectively produce. When you are a one man shop, there is a certain limit to productivity. Instead of raising price to create a ceiling on demand, Pete is pricing it at a point he feels is acceptable, and not shouting from the rooftops on it. Course I am saying a lot for Pete on my own, and thats probably not my place.
I would also say mass is a necessary component of an arm to work effectively with the VTAF. Interesting point. I have an exposed armboard on my table, which allows me access to the bottom of the arm. I believe additional weight can be added, I may experiment with this in the future and see what happens.
Sorry to hear the downturn in the economy has affected you, it really is a problem everywhere. Don;t know what your business is, but I don't think many industries have been spared the effects of the recession, nor have they fully recovered. Sounds like you have collected some wonderful analog pieces over the years though. Wish I could have had the foresight and money to have grabbed some of the great vintage pieces when they were cheap. Would love to experiment with some of the big Denon direct drive assemblies, and put them in a new plinth.
Regards
Mister Pig
