IS this good Cabinet foam lining specs
0 Members and 1 Guest are viewing this topic. Read 1397 times.
mclsound
« on: 20 Jan 2011, 12:00 am »
My cabinet will hold 2/12"woofers crossed at 200hz and 1/12" midbass crossed at 200-800hz(separate box inside) and wondering if this is a good spec for a foam lining
face
Re: IS this good Cabinet foam lining specs
« Reply #1 on: 24 Jan 2011, 06:43 am »
I would recommend No Res or Blackhole 5 instead.
wushuliu
« Reply #2 on: 24 Jan 2011, 06:47 pm »
If they are primo drivers and these are speakers you'll be content with for a while, then No Rez/BH5 sounds better option. However considering the cost of No Rez and BH5, it would probably cheaper to build a more inert cabinet. Or do the Home Depot vinyl floor tiles method w/ the acoustic foam on top. It would be hard for me to spend as much on No rez/BH5 as on the drivers used.
face
« Reply #3 on: 24 Jan 2011, 09:25 pm »
BH5/NR are still beneficial with inert cabinets, they help with internal reflections and standing waves.
nottaway
« Reply #4 on: 26 Jan 2011, 11:13 pm »
If you use foam it can be found cheaper....
