0 Members and 1 Guest are viewing this topic. Read 9016 times.
Blakep,I thought it important to point out that both overhang and angle will change, if mounting distance is even slightly off. That's why I posted, not to contradict what you said, which seemed correct.neo
RE: SkatingThis is probably the most misunderstood phenomena with pivoting arms. Skating is caused by stylus drag. This is not just a matter of simple friction. Stylus drag is a byproduct of tracking and cart offset angle. To complicate matters further, groove modulation (velocities) have a great effect, and vertical contact area of the stylus seems to have an effect. That is why skating requirements will vary.
I recommend using a blank disc to set the anti-skate.
after taking a closer look at my arm/cartridge mounting, i have changed a few settings based on the user feedback:- i raised the arm base 1.5mm (the width of a penny)- confirmed the spindle to arm distance is as close to 240mm as i can measure. The Jelco comes with a plexi ruler that fits over the spindle with a hole for tracing the centre of the mounting hole.- increased the tracking force to 2.65g - tightened all screws and allen keys- realigned the cartridge to DIN Baerwald: overhang 15.5mm with null points at 63.103 and 119.173. This puts the cartridge very square in the headshell.- set the arm anti-skate to 2.0. There is still an issue with buzzing on HFNTR for track 4. i used Neo's technique of sighting the stylus through it's travel on the record surface. this proved to be very revealing to see the arm actually 'pull' on the stylus.Results:the harsh issues with 's' sounds is vastly reduced across the surface of the record. Also, overall dynamics seems expanded a bit, and subtitles in low end seem more apparent. Mids and vocals are crystal clear.Gotta say thanks to everyone. this was a great learning experience and gives me an expanded base to learn and converse about the effects of fine tune adjustments. This seems like a situation where constant learning and adjusting is part of the fun. Thanks!
thanks for your suggestions -- makes sense to hold out for a real top notch phono stage.
thanks for your suggestions -- makes sense to hold out for a real top notch phono stage.i'm looking at a Midas aluminum body; any direct experience?http://www.audiogon.com/cgi-bin/cls.pl?anlgcart&1300966913&/Midas-Denon-103-103R-aluminum- i know the guy who builds them through another forum (lenco heaven). seems like a good design and quality.
i think i'm going with the Midas. I like the idea of the heavy aluminum body. The Lenco guys are really set on it. I'll let you know how it goes when i install it all.
It might be worth investigating the optimal total mass of a 103 set-up. I read somewhere that a user thought a range of 25 to 28g for cart weight + arm eff mass was best. With a 21g arm and 14g cart, you'd be at 35g. A little more actually if a heavier counterweight is needed. I'm not saying this is fact, only that it would be worth looking into. Maybe a lighter wood body without a heavy top plate would work out better, I don't know. It might just be results one person had with the arm(s) he used. neo
