For James. about warranty!
0 Members and 1 Guest are viewing this topic. Read 1508 times.
lanchile
« on: 19 Jan 2011, 02:41 am »
I have a question about warranty. I know if I "modified" parts inside circuit the warranty is avoid right?. But what about if I make about 20 small holes on top of chassis of a B60R to get more ventilation inside of amp. will this avoid warranty?. I noticed that the way inside of amp is "enclosed" by the heat sinks so there is not a path to circulate the heat inside.I know it uses the chassis to dissipate heat too but, there is a lot of heat "trapped" inside the amp and I would love to do this to let some heat out. some may say if I drill some holes on top they will let some dust in and the amp will live shorter life. how about those old ones with a lot of ventilation on top that lasted over 25 years and still working today. or should Bryston come up with a better way to dissipate heat inside kipping a closed chassis but with "external" heat sinks. or just let it go and leave it the way it is?
  • The Demo is Everything!
    • http://www.bryston.com
Re: For James. about warranty!
« Reply #1 on: 19 Jan 2011, 01:00 pm »
Hi,
As long as the mod does not cause the amplifier to fail then the warranty will be covered.
james
lanchile
« Reply #2 on: 20 Jan 2011, 02:07 am »
Wow, good to know James. Thanks for answer. :thumb:
Diamond Dog
« Reply #3 on: 21 Jan 2011, 04:52 am »
You might want to consider how that mod might affect resale or trade-in value before that drill starts spinnin' unless you're thinking that B60R is your BFF, sir. Just a thought FWIW...
D.
Calypte
« Reply #4 on: 21 Jan 2011, 05:22 am »
Maybe what you think of as "heat" is the proper operating temperature.  Maybe Bryston designed it that way intentionally.
1ZIP
« Reply #5 on: 21 Jan 2011, 05:40 pm »
FWIW -
If you think it is running hotter than it should, then I'd send it in for an evaluation/repair.  Otherwise I'd leave it alone and let it operate as it was designed.  A question I would be asking: "is there a history of heat related problems with the B-60's"?  My guess is probably no....but it's your gear and you have to do what makes you comfortable.
