0 Members and 1 Guest are viewing this topic. Read 7126 times.
I'd say that you may need to be concerned, it depends on how your roof is made. I have that type of dam every year with no leaks. I presume that there is ice and water shield under my shingles.
the ice dams can prevent proper drainage and force the water up under the shingles causing rapid deterioration.
How does this deteriorate the shingles?
In the case of our condo association, there was a lot of curling,etc. - could be from freeze / thaw cycles once the water was under the shingles. Could be from the fact that shingles are designed to have water on the top surfaces- the undersides not so much. But we digress. Tires, Django. Tires.
Blizzaks are highly regarded
The OP did ask about the ice dams . IMO what is causing the damage to the shingles is the same thing that is causing the ice dams in the winter: improper ventilation.
Funny I used to speed ALL the time, way ove the limit, and never got caught. Then as I got older, I tried to slow down, and Damn I get tickets all the time!Karma?
... try to get the cop laughing and don't give him any crap.
Yeah, my father taught me that buddy system and it works great.
