Stacking Amps
0 Members and 1 Guest are viewing this topic. Read 2010 times.
Fullvolume
Stacking Amps
« on: 18 Jan 2011, 01:30 pm »
What is the minimum amount of open space an amp should have in order to 'breathe'.
I what to place 2 7B's one on top of the other with maybe a spacer of some sorts or is this a bad idea all together.
« Last Edit: 18 Jan 2011, 08:37 pm by Fullvolume »
Levi
Re: Stacking Amps
« Reply #1 on: 18 Jan 2011, 01:37 pm »
I would say at least several inches.  I had mine stacked before and works fine.  Currently, I have mine as close to the speakers as possible using short speaker wires to take the advantage of having mono amps.
Stacked 7B
  • The Demo is Everything!
    • http://www.bryston.com
Re: Stacking Amps
« Reply #2 on: 18 Jan 2011, 02:07 pm »
Generally 1 3/4 inches is considered adequate as long as there is reasonable air circulation around the amps.
james
Napalm
Re: Stacking Amps
« Reply #3 on: 18 Jan 2011, 06:49 pm »
How about stacking them side by side in vertical position? (i.e. rotate the previous pic 90 degrees)
Nap.  :scratch:
srb
Re: Stacking Amps
« Reply #4 on: 18 Jan 2011, 07:06 pm »
The vertical heat sinks are designed for bottom to top convection air flow through the fins.  I'm sure it would work, but I have to think that would be less than optimal orientation.
Re: Stacking Amps
« Reply #5 on: 18 Jan 2011, 07:17 pm »
Correct - the heat sinks are designed to act like a convection chimney - in fact the heat sinks are computer modelled to provide as much efficiency and heat dissipation as possible.  Even changing the space between the fins a little will cause a loss of about 15% efficiency.
James
