and what is better choice for interconnect from step up to
0 Members and 1 Guest are viewing this topic. Read 1532 times.
papagenohyun
what is better choice on interconnect from step up tranny to linestage?
in Jim's writings on loading, it seems that IC with lesser capacitance is better.
i have to choose one between van den hul d-102, and van den hul d-501.
d 102 is not assorted as phonocable by van den hul but it has lower capacitance than 501.
501 is highly recommended and used throughout many tonearm company.
 capacitance : 501 has 75pF, and 102 has 37pF.
what do you think about that?
what are you going to choose Jim? if you were me
thanks.
hagtech
    • http://www.hagtech.com
« Reply #1 on: 19 Mar 2004, 03:09 am »
In my humble opinion - it is best to use twisted pair wire between cartridge and step-up (capacitance isn't really an issue here), and then coaxial wire from output of step-up to phonostage.
This is because interference on the primary is magnetic, and electrical on secondary.  You need to optimize for both worlds.  On secondary, the capacitance is critical.  That is why I use short coax wires on the step-up I sell and a super-low capacitive input design on the Trumpet.  You try to maximize bandwidth extension at both ends and minimize external noise sources.
jh :)
