BDP-1 with B100SST with DAC
0 Members and 1 Guest are viewing this topic. Read 1252 times.
audioman999
« on: 17 Jan 2011, 12:36 am »
When using the B100SST with DAC, is there any advantage of using the BDA-1 when hooking up the BDP-1?
Also if using the DAC on the B100SST am i limiting the benefit of using a BDP-1?  Should i just use a squeezebox or similar to stream the digital to the integrated?
alexone
Re: BDP-1 with B100SST with DAC
« Reply #1 on: 17 Jan 2011, 04:47 am »
audioman,
i've personally never auditioned the built in DAC of the B100. but one thing compared to the BDA-1 is for sure: the B 100's digital inputs 'only' accept up to 108 khz!!! playing 176 khz or 192 khz through the B100 is not possible.
the BDA-1 can easily handle these high resolution rates and is therefore the perfect match for the BDP-1 if you want to playback high resolution files!
i don't know if a squeezebox is able to playback up to 192/24 files?
al.
StigO
« Reply #2 on: 17 Jan 2011, 07:21 am »
Squeezebox Touch can only do 24/96.
