XLR connectors
0 Members and 1 Guest are viewing this topic. Read 1901 times.
dhsettim
XLR connectors
« on: 17 Mar 2004, 11:35 pm »
Hi John, in your kit instructions it says that the XLR connectors on the preamp back panel are "female". Is there a convention of which way to use male and female connectors, as I thought a "male"would have been better here on the input so there would be no chance of shorting the pins on the input cable ? Does that make sense?
And do you or anyone else have a preference for metal bodied XLR over plastic bodies--or vice versa?
thanks, tim
dhsettim
minature XLR
« Reply #1 on: 22 Mar 2004, 05:48 am »
I found some mini XLR connectors which look great with very small pins and small bodies so will go with them. As I have braided my own interconnects I can customize the connectors.
Anyone else tried them?
tim
Peter B
XLR connectors
« Reply #2 on: 22 Mar 2004, 03:02 pm »
Hi Tim,
On the preamp the xlr-outputs are male, and the xlr-inputs are female.
This is a standard.
Peter B
dhsettim
thanks Peter
« Reply #3 on: 24 Mar 2004, 07:56 am »
Thanks Peter, that's the way I thought it should be.tim
