0 Members and 1 Guest are viewing this topic. Read 12607 times.
Would like to add a bit more power to the ST/R's to really see their potential. How would I go about adding an additional amp to power the sub section of these. My source is a Pioneer SX-1250 which I would like to use to power the mids and treble. I know I can use an external amp and bypass the receivers amp but don't want to go that route. Don't know if what I'm asking is possible but you don't know until you ask.Thanks,Brian
You would need a couple of Y-splitter cables, and of course another amp: (another Pioneer sx-1250 would work if you can find one cheap)Pull the pins that connect the Pioneer preamp to it's amp section (preout/amp in). Insert the splitter at each preout (L+R) at the Pioneer preout jacks.....and feed the split connection back into the Pioneer, and the new amp.Dave
So does that mean something like the Behringer wouldn't work because I can't control the volume?
So if I understand correctly, I would use the Y splitter cables off the Pioneer to the Behringer. Once the volume level is set on that, then both amps volume is then comtrolled by the receiver. Is that right?
i think your receiver has pre outs & main ins, which means you could actively cross over your main speakers as well - you would run the receiver's pre outs to an active x-over; then run the x-over's low pass to the sub amp(s), and the x-over's high pass back into the main ins of your receiver. or, if you want a tube amp for the main speakers, you would run the hi pass from the x-over to the tube amp, and the low pass to the the receiver, and power your sub(s) from the receiver's amp. the x-over will be able to gain match the amps...doug s.
Hi Doug,Not sure how well an active XO added to the passive would work. The OPs speakers already have passive XO's in place. Have you employed this before to a good advantage?
Thanks for spending the time for the information guys. Its much appreciated. Now I have to decide what's going to be the best way to do this for me. I really don't want to to make this complicated because this is why I sold off my old system and took this route. The wife could never figure out what did what and which buttons to push. I just want to have enough power to be able to crank it up when I want to. The pioneer does a darn good job but I worry about clipping the speakers.Brian
Hi Brian,all those guys with great info might have missed something.Most sub woofers out there have built in amps,most often in the back.I built a sub from Parts Express components.At first I used bi-amping with a little Dyna-35 for the upper range,crossover,and a Marantz 500,mono 125 watt solid state amp.I then bought from Parts Express a BASH sub amp from Canada,for about 100 bucks,300 watts.I cut a hole in the sub and installed it.It has a built in crossover,output level,and frequency selection.I could eliminate my crossover and Marantz now,and I used that Y cable connection idea.With 2 cables coming from my cd player to 2 Y cables,1 Y cable from the cd to Pioneer receiver,and the other Y cable to the Bash sub amp,no speaker wires needed to the sub,just the Y cable.The downside is for me,I can only play my sub when my landlord brings his kids to the parents,X-mas time ect.....cause I can scare the luvin beJesus out of them living across the hall.....good luck Bri...Mark Korda
I think the title of the thread might cause a little confusion.Brian, is looking to add an amp (thereby biamping) to the woofer section of his ST/R's, and the woofer section is quite similar to the LARGER Sub.So he is not actually looking to add a SUB, but wondering whether a SUB AMP would power his WOOFER section of his mains.
