Advice needed for AV Remote/ Smartphone Combo
0 Members and 1 Guest are viewing this topic. Read 1108 times.
rajacat
  • Washington State
« on: 11 Jan 2011, 09:34 pm »
I'm looking for a smartphone that can also control my Squeezebox, satellite TV and DVD player. Is this too much for one device to handle efficiently? Would I be better advised to separate the home devices from the smartphone? My ATT cell contract recently expired so I'm using this as an excuse to get rid of the 4 remotes cluttering the cocktail table and purchase a smartphone. :D
-Roy
eclein
Re: Advice needed for AV Remote/ Smartphone Combo
« Reply #1 on: 11 Jan 2011, 10:03 pm »
I can only give you info on Squeezebox apps, I have a free app on my Android phone that is basic but works fine and ipeng on my ipod touch which was $10 and is fabulous so either way you go you got the SB covered.  :thumb:
mcgsxr
« Reply #2 on: 11 Jan 2011, 10:34 pm »
Not sure any smartphone has IR natively (it can be added to the iPhone with a peripheral) so I am not aware that any one device will do it.
I use a Logitech 880 as my single HT remote.  It is fantastic. PC setup, one touch macros for activities.
For PC music control I use iPeng on my iTouch (on it posting this too).
Used kit rocks!
rajacat
  • Washington State
« Reply #3 on: 12 Jan 2011, 01:37 am »
Hmmm.....I wonder if the 880 will work with my Squeezebox? Since it's built by Logitech it should.
Roy
