Tempest Bi-Amping?
0 Members and 1 Guest are viewing this topic. Read 2262 times.
Brian
Tempest Bi-Amping?
« on: 17 Mar 2004, 10:30 am »
Hi
Anyone who has experience with bi-amping using the Tempest as pre-amp?
rosconey
Tempest Bi-Amping?
« Reply #1 on: 17 Mar 2004, 11:45 am »
klaus has extra outs for that if you wish-or use them like i am going to for subs-
Brian
Tempest Bi-Amping?
« Reply #2 on: 18 Mar 2004, 09:06 am »
I am thinking of using the Stratos for LF and the Khartago for HF.
rosconey
Tempest Bi-Amping?
« Reply #3 on: 18 Mar 2004, 11:04 am »
sounds like a plan-good luck :mrgreen:
Eric
Tempest Bi-Amping?
« Reply #4 on: 18 Mar 2004, 01:43 pm »
Wouldn't it be better to use identical amps to biamp due to the difference in gain from using two different amps?
Brian
Tempest Bi-Amping?
« Reply #5 on: 7 Mar 2005, 08:49 am »
Hi guys
I had the chance to try my Tempest, Khartago and Stratos Plus in a Bi-amp set-up.
The owner uses Harman Kardon Signature 1,0 and 1,5 to bi-amp his JBL 250. I listend to this set-up in about an hour and must say it sounded good.
We switched to a complete Odyssey set-up. As I only have 1 out on the Tempest we used a Y-connector which worked just fine.
The sound of the set-up was every bit as good as with the H/K. If anything the sound was a bit more refinded with the Odyssey than the H/K. The mid was more detailed and the bass deeper.
All in all the Odyssey/JBL set-up was really good. Maybe not as Rock'n'Roll as the with the H/K, but more refinded without loosing dynamics. More a  matter of taste than quality. I can recommend anyone who has JBL 250 to try Odyssey.
Brian
Edit:
Link to the danish site Hifi4all.dk with pictures from yesterday at the bottom at the page...
http://www.hifi4all.dk/forum/forum_posts.asp?TID=14077&PN=1&TPN=13
