Cornet 2 cap replacments
0 Members and 1 Guest are viewing this topic. Read 1665 times.
tubesorbust
« on: 10 Jan 2011, 03:02 pm »
The following caps are discontiuend via digikey and this is what they recocommended.  I figured I'd ask the community for some input.
C204: original discontinued part: P3497-ND / recommended digikey part: BC1599-ND
C100, C101: original discontinued part: P11423CT-ND  / recommended digikey part: 445-2429-ND
poty
Re: Cornet 2 cap replacments
« Reply #1 on: 10 Jan 2011, 07:08 pm »
For P3497-ND more suitable can be:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=399-5470-ND(fits better than BC1599-ND)
or
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=P10470-ND(better tolerance)
but IMHO - in the RIAA EQ you may want to use something better. (I'm not a fan of Micas, but
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=338-2624-NDseems more suitable; I don't even speak about nice audio-grade caps suggested in several posts already).
According to C100, C101 - there was a discussion about them already:
http://www.audiocircle.com/index.php?topic=88517.0
