Hi Frank, Hot Tubes!
0 Members and 1 Guest are viewing this topic. Read 1999 times.
orthobiz
« on: 17 Mar 2004, 03:34 am »
I just bought a new stand for my components, a Q4 Quadraspire. It is configurable and looks great in my room.
I bought 140 mm posts between the shelves housing my T7 ECR. This leaves 50 mm, about 2 inches, above the preamp and it is open on all 4 sides. It is running a lot hotter than when it was totally out in the open, I am wondering if I need taller posts?
My 550 EXR is doing a lot better with 3 inches of clearance above it, although the heat sinks are hot (I guess that's what they are for).
Do I get the 180 mm posts to have the T7 run cooler? Or should I just let the tubes glow? The sound, by the way, is glorious!
Biz
orthobiz
« Reply #1 on: 19 Mar 2004, 04:14 am »
My subject title should read:
Hi Frank, Hi Larry...
biz
