Based on the existing setup, treating those 2 front corners behind the speakers is likely your best course of action. At some point, you might also want to consider some bass absorption hung horizontally and up high on the rear wall behind the seating.Bryan
As far as moving the speakers out in the room more..that would be a tough sell. Wifey's idea ...is all componets should be as visually unobtrusive as possible..ie huge entertainment center with all gear inside..she wasn't real happy when I upgraded to mono bloc amps and they were outside of the cabinet.
How much further can you move the speakers out into the room?
...As far as moving the speakers out in the room more..that would be a tough sell. Wifey's idea ...is all componets should be as visually unobtrusive as possible..ie huge entertainment center with all gear inside..she wasn't real happy when I upgraded to mono bloc amps and they were outside of the cabinet.
scp2,The simplest solution for your boomy bass might be to move your couch forward about 6in. to 1 foot. The boom might disappear just by moving your head out of the standing wave node you are currently sitting in. Scotty
