Kismet Mono's - switching from RCA to XLR
0 Members and 1 Guest are viewing this topic. Read 1548 times.
hpc
« on: 9 Jan 2011, 12:10 am »
Hi All,
Wanted to see how the Kismet's sound using XLR's versus RCA's.
Is there an internal jumper or switch that needs to be set?  If so, details please.
I could call Klaus, but it's the weekend and the Colts game is coming up; he DESERVES a break away from audio.
Thanks and Cheers,
LDM
golfugh
  • Dead Can Dance - Into the Labyrinth
Re: Kismet Mono's - switching from RCA to XLR
« Reply #1 on: 9 Jan 2011, 01:06 am »
RCAs and XLRs are both hot.  XLRs are fed from the RCAs, not balanced, but I use the XLRs.  No sound difference, but quieter.
hpc
« Reply #2 on: 9 Jan 2011, 02:36 am »
Thanks for the info.
Cheers!
LDM
gtb75
« Reply #3 on: 9 Jan 2011, 05:20 am »
It is my understanding that the amps are not a balanced design, so there should be no difference.  I had some hum issues with XLR's, so I switched to RCA's - problem solved.
