SP2 and AppleTV - What is the quality from iTunes?
0 Members and 1 Guest are viewing this topic. Read 1125 times.
JohnnyB
I have my new second generation AppleTV feeding my SP2 via an Optical audio cable.
What are your thoughts on the quality assuming I have Apple Lossless ripped into iTunes, which wirelessly sends their digital bits down to the AppleTV.
Thanks, JohnnyB
  • The Demo is Everything!
    • http://www.bryston.com
Re: SP2 and AppleTV - What is the quality from iTunes?
« Reply #1 on: 7 Jan 2011, 02:25 pm »
Thanks, JohnnyB
Hi Johnny,
It should be fine but limited to 44.1 resolution I believe.
james
Levi
« Reply #2 on: 7 Jan 2011, 02:27 pm »
The optical input(s) can also decode 5.1 audio from my sons' Xbox 360.
