Purity Audio Basis Pre and Basis Pre 1.1 special offers
0 Members and 1 Guest are viewing this topic. Read 1345 times.
Bill Baker
    • Musica Bella Audio
 Greetings AC members. It's been a while since we posted anything so we figured now would be a good time to show this offer.
Even though Purity Audio Design is not a custom manufacturing company, it is here that the first Basis was purchased so a special offer seemed appropriate. In fact, the first production Purity Silver Statement went to an AC member.
Basis Pre 1.1
We will offer 5 custom pieces at a special price of $2,495. Being a limited production run, we will be offering a custom option to the mix. You will have a few choices on the color used for the acrylic uprights to build your unit. We can also offer different colors for the top plates as well. Solid or transparent colors are available.
 Construction is all 1/4" thick material (including top and bottom plates) with the uprights being 7/8"- 1" diameter thick acrylic.
 You also have your choice of LED colors for the source indicators and power supply LED. (Red, Blue or Green)
Basis Pre Linestage -  http://www.purityaudiodesign.com/purity%20basis%20linestage.htm
 Basis Pre - the original
Remember the original Basis Pre? We are bringing this back. The original Basis is the same circuit as the Basis Pre 1.1 but does not use the polypropylene power supply or the Alps remote volume.
 For $1999, what you get is the Basis circuit with high quality Electrolytic capacitors bypassed with polypropylene capacitors. The standard volume is a non-remote stepped attenuator with Dale/Vishay resistors. You still get your LED source indicators.
  AND------
 We are also going to bring back the real wood veneered wood chassis for a limited time. So now you have your choice of acrylic or real wood veneer.
