Audio/Video Gear and Systems
The Vinyl Circle
woodsyi
buzz/hum
buzz/hum
0 Members and 1 Guest are viewing this topic. Read 1179 times.
parr3n1
buzz/hum
6 Jan 2011, 06:05 am »
I have a buzz/humm in the right channel. When I disconnect the phono cable the buzz/humm disappears. I have a Grace 940 tonearm with Cardas Golden Ref. cable. The cartridge is a mm type. Any suggestions please??? Thanks
Wayner
Re: buzz/hum
6 Jan 2011, 09:45 am »
1. See if any of the leads attached to your cartridge have come loose.
2. Check shield of offending channel, to make sure it is making contact.
3. You never said that while you had hum, you also had music? Or not?
Wayner
parr3n1
Re: buzz/hum
Reply #2 on:
6 Jan 2011, 10:12 am »
Yes I do have the hum with the music playing and without the headshell installed on the arm. The cable is brand new from Cardas. How do I check the shielding? Nothing looks amiss on the outer covering. I have another cable set that I will try to install tomorrow. Thanks
Wayner
Re: buzz/hum
Reply #3 on:
6 Jan 2011, 01:10 pm »
Is your ground wire attached (sorry for stupid question)? Take a volt/ohm meter and do a continuity test on the center pin and shield of the offending channel. The pin will go to one of the contacts on the other end as well as the shield.
Wayner
The Vinyl Circle
woodsyi
buzz/hum
