Which cable would you use to connect a BDP-1 and BCD-1 to BDA-1
0 Members and 1 Guest are viewing this topic. Read 1086 times.
Bugsy
Hi Guys
I need to choose one cable, a SPDIF COAX with RCA connectors or the SPDIF 75 ohm with BNC connectors as BDP-1 is coming soon.
How some one mentioned to me that you can get a SDIF COAX with RCA connectors that is 75 ohm.
I all ready have a digital 110 ohm AES/EBU cable so I can either use that between the BCD-1/BDA-1 or between the BDP-1/BDA-1.
My system is made up of a Torus RM20, Bryston 14B-SST2, BP26/MPS-2, BDA-1, BCD-1 and B&W 703 speakers, Transparent MusicWave Super Speaker Cable, MusicLink Super Balanced Interconnect x2 with a Premium 110-Ohm AES/EBU Digital Link cable.
So what are your thoughts.
Thanks Larry
BrysTony
I would use your AES/EBU cable for the BDP-1/BDA-1 and for the BCD-1/BDA-1 I recommend the Bryston digital cable with RCA/BNC connector.  It is a good cable for $100.  http://bryston.com/canare.html
Tony
