0 Members and 1 Guest are viewing this topic. Read 37541 times.
I believe this is part of what Putz was asking, in-directly at least.I've been curious about this as well. And have wondered where it might be best to put the dollars in a similar situation, so will ask the question a bit more specifically? (Since the responses so far are focused on which tubes / which source might be best for Putz). Do AC members have an opinion on: the trade-off between a quality tube upgrade on a more 'basic' component vs. putting the dollars spent on the tubes into a slightly higher level component?Using Putz' situation, for illustration purposes only, the Jolida 502BRC is lets say roughly around $1000. A set of 4 KT88 Premium A Zs is roughly around 500. (Note: Using rough numbers for example sake).So at one extreme would be a stock integrated at roughly $1500vs. the 502BRC or any other similarly priced integrated (that is, irrespective of specific amp) + top of the line Shuguangs.And, of course the variations in between, utilizing less costly tubes.Any perspective and thoughts on this.Thanks,David.
I don't want to spend more than $300 on the tubes I ultimately buy. But I was also asking if an amp like my Jolida would get the full benefit of an upgraded tube like the Treasure or if I was better off with a Penta, etc. for less $.
For my hard earned dollars, the mega buck tube upgrades are very low on my priority list. I think your money is better spent other places, especially the output transformers when it comes to tube amps. Now, I can't say that just because an amp costs more means it has better iron, but I would probably give my money to a designer/builder that focuses more of the product budget on transformers than tubes. I think a well designed amp, with quality iron, and good parts (NOT $200 capacitors and wire that goes for $10 bucks a foot) should perform very well with just about any tubes. I have spent some bucks on tube upgrades for some of my headphone amps and did notice a difference, but not nearly the difference I've seen by spending that money on quality transformers.
Yes iron, caps etc all matter. As a fellow DIYer I agree whole-heartedly. I have gigantic Edcor transformers, oversized oil power supply caps Jensen coupling caps etc etc. Where we disagree is when you do all that great stuff and then put some $hit tubes in your system. Yes it will sound better than a bad amp with great tubes, but trust me as I have used EVERYTHING the Treasures are the best and quite literally nothing I have tried NOS or otherwise has come close. Combine them with some Herbies tube dampers and it's a game changer my friends. Tube rolling for me.... A thing of the past.
