0 Members and 1 Guest are viewing this topic. Read 6853 times.
Why not reverse your set up putting the speakers at the window wall ? charles
Why not reverse your set up putting the speakers at the window wall?
Those are two really nice looking rooms you have. Your actual set-up room is small, but with that large opening in the front between the speakers, my guess is that it will sound like a much larger space. That opening also removes a normal reflection point to the extreme. You will probably get a great depth of image.With rooms as nice as yours I would think aesthetics will also be important in your treatments. For the higher frequencies I would try some common furnishings placed to scatter the soundwaves as much as possible. Tall pieces of sculpture and artificial (or real) plants can help a lot and you may already have access to these. You can also build diffusion devices for wall attachment that could very much resemble artwork. I have to give a little more thought on how to add in bass trapping that goes well with everything else. But, really fabric covered traps of various colors and shapes can also be made to fit well into a rooms like yours.
The family might object to the new sofa placement in front of the doorway.
We do have some large sculptures that could break up the space (nothing quite like your "extruding man", though--that's pretty cool).
I still have a concern about the open doorway next to corner #1 (right speaker) and how this might negatively impact soundstage.
Sheep represent potential placement for absorption. I know they're hard to hang, but it fits my budget and we need the meat.
