0 Members and 1 Guest are viewing this topic. Read 2669 times.
I have used an exo-skeleton for bracing.Bösendorfer uses techniques similar to what you describe.http://www.gerhardfeldmann.com/bony-history/Floorstanding.htm?page=category&cid_name=Floorstandingdave
Generally speaking, metal rings like a bell . . . bad. However, metal, when bonded to mdf or wood can provide additional mass damping . . . good.
I don't see the connection between what I see on that site and this ... whimsy(?). Actually, from all I can see, the Bosendorfers (how do you get that umlaut over the "o"?) are pretty conventional boxes, aren't they?
The design I was thinking would be completely different. Has anyone ever built an enclosure out of metal? What does that sound like?
Some designers have swum against the stream. Back in the 70's Jeff Martin of Speaker Craft told me of an old man speaker builder who would occasionally bring in his home-made speaker for comparison to their kits. His secret to sound was that he made the cabinet like a violin. Same thin varnished wood, etc. To him the resonance of a musical instrument was only able to be reproduced if the cabinet resonated like a musical instrument. Jeff reported that the sound was actually not so bad, at least on violin music. In the 80's one British maker, Mission, admitted that they designed a resonance in their smallest bookshelf speaker to contribute warmth.
The truth about this approach is that ANY resonances in the cabinet, intentional or not, produce their own separate waveform which will sometimes sum with the drivers waveform ... and other times cancel. It's nothing more than even order distortion products, and will be wildly and uncontrolably out of phase with the wavefrom coming from the drivers themselves. I can't imagine any situation in which this would be desireable. The job of the drivers is to reproduce the recording as accurately as possible ... anything the enclosure contributes is only going to contaminate the waveform created by the drivers.
