0 Members and 1 Guest are viewing this topic. Read 17449 times.
Hi to all,I am interested ? is this FRX model is sutiable in the another concept, but with 2x15" on each side ?thx. for the reply
Open baffle and no crossover, it almost has to sound great.
http://www.decware.com/newsite/FRX.htmlHow it came about: http://www.decware.com/newsite/paper95B.html
Hi OPNLY BAFLD,This big Alnico looks good. I wonder how this OB panel works ?? Could be as a resonator or Iam wrong ??Thanks, Gustavo
It's not Alnico but neodymium and most of the huge can on the back presumably houses the inductor, as described on the page I and opnly bafld linked to. I imagine if you could see the magnet you would be underwhelmed, since neo magnets tend to be small.
Gustavo,The front baffle panel is somewhat of a resonator. If you look carefully at the back just under the driver there is a small wooden panel. The pulling out or pussing in of this panel allows you to adjust the bass response to fit the room. The lower frequencies resonate in the bass cavity below the sliding panel.I purchased the plans for the ZOB last year when it first came out, but haven't had the chance to bulid them yet.With these new drivers it may be happening soon. Chris
Do you know if this OB is a precision project for good musical effect??Maybe doing a wider panel at naked eye for a bigger FR could sound good?? Or it have rocket science ?? Best, Gustavo
