VRX*1 Balanced Cable Set question
0 Members and 1 Guest are viewing this topic. Read 2268 times.
SkyBlue
« on: 31 Dec 2010, 11:12 pm »
Can i use the VRX*1 balanced cable from the VDA-2 to the inputs of a Behringer DCX2496 or should there be a preamp in between?  I have a VPC-3 passive controller but it doesn't have XLR in/out.
CIAudio
Re: VRX*1 Balanced Cable Set question
« Reply #1 on: 1 Jan 2011, 01:27 am »
VRX-1 cable set will give the VDA-2 true balanced output on standard XLR connectors.
Hard to give you any configuration advice without a better understanding of what you're trying to do. Send me an email if you want to discuss it.
[email protected]
