Internal Damping For A SS Amplifier
0 Members and 1 Guest are viewing this topic. Read 1498 times.
ZLS
« on: 28 Dec 2010, 08:26 pm »
    Hello,
    I am looking for advice, suggestions, help in that I want to add damping material to the inside of the case of my Edge Amplifier.
    Any suggestions?  Warnings?
    I am thinking in terms of damping sheets, but I don't know what is feasible or even safe.
        Thank You
face
Re: Internal Damping For A SS Amplifier
« Reply #1 on: 29 Dec 2010, 03:11 am »
I've used Dynamat Extreme in similar applications and never had an issue.  Just double check that you have enough clearance, I've had to cut irregular shapes for inside CDP's.
satfrat
« Reply #2 on: 29 Dec 2010, 03:18 am »
Flat top Audiopoints w/discs underneath all my gear is always a nice counter vibration touch beyond internal dampening, works for me anywho.  :thumb:
Robin
rollo
  • Rollo Audio Consulting -
« Reply #3 on: 29 Dec 2010, 05:38 pm »
   Compressed wool. 3M damping sheets, Dynamat, raw silk, wood clamps. Have fun trying.
charles
