digital transferring.
0 Members and 1 Guest are viewing this topic. Read 2797 times.
redbook
  • the music is the blood...........
« on: 24 Dec 2010, 10:42 pm »
Could James or other members suggest a good cable to use between my cd1 and possible future bda1. Is jitter increase by this or it insignificant? Thanks for any ideas  . :?  By the way  excuse my lousy typing on previous post  :duh:
srb
Re: digital transferring.
« Reply #1 on: 24 Dec 2010, 10:57 pm »
The great thing about many forums, including this forum, is that you can edit previous posts for lousy typing or misspelling.
Bugsy
« Reply #2 on: 24 Dec 2010, 11:35 pm »
I use a AES-EBU Digital Cable and make sure it is 110 ohms digital XLR. Bryston sells one at a reasonable price but you can pay more. I use a AES/EBU Digital Cable, 110 ohms digital XLR between my Bryston BDA-1, and my BCD-1. I am looking at buying a BDP-1 so I will use that same cable between the BDA-! and the BDP-1 and use a BNC to BNC cable between the BDA-! and the BCD-1
alexone
« Reply #3 on: 25 Dec 2010, 12:20 am »
Bugsy, the BCD-1 has no BNC out...therefore you cannot use a BNC to BNC Cable?!?!?
BNC to RCA (Coax) would work...
al.
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
« Reply #4 on: 25 Dec 2010, 07:00 pm »
I always thought that 0's and 1's were just that, and that they would not really need some expensive high end cable to get from one place to another. I was proven quite wrong there...
I for one think you cannot go wrong with Nordost Cables. Not cheap, but in my opinion more than worth their money.
Which I think is weird. There is no standard in the connections Bryston puts on its equipment. The BDP has BNC and USB-A, the BDA has USB-B, the BCD has RCA...
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #5 on: 25 Dec 2010, 07:16 pm »
UH?
james
Robert D
« Reply #6 on: 25 Dec 2010, 08:03 pm »
Phil A
« Reply #7 on: 25 Dec 2010, 08:08 pm »
1s and 0s are not what gets transported via a digital audio cable
Bear Heath
« Reply #8 on: 25 Dec 2010, 08:23 pm »
Phil,
is what is actually transported electrical impulses that represent the 1s and 0s? How does the cable influence or degrade the impulses?  Thank you.
Phil A
« Reply #9 on: 25 Dec 2010, 08:33 pm »
Phil A
« Reply #10 on: 25 Dec 2010, 08:34 pm »
You can actually get the same general type of problems on a digital coax as with analog cables.
srb
« Reply #11 on: 25 Dec 2010, 09:54 pm »
There is no standard in the connections Bryston puts on its equipment. The BDP has BNC and USB-A, the BDA has USB-B .....
It is quite standard to use USB Type A connectors on Hosts and USB Type B connectors on Peripherals.
James, you are once again posting the back panel photo of the BDP-1 with USB and Ethernet legends reversed.  Why not just delete that photo once and for all? !
« Reply #12 on: 25 Dec 2010, 11:10 pm »
Ya I know -   it's the only one I have on my home computer :D
james
« Reply #13 on: 25 Dec 2010, 11:17 pm »
james
Bear Heath
« Reply #14 on: 26 Dec 2010, 01:12 am »
