damaged tweeter on vr 4 gen 3
0 Members and 1 Guest are viewing this topic. Read 2596 times.
emilraaf
« on: 23 Dec 2010, 10:48 am »
Hi vr lovers :D. I have a problem. The rear tweeter on my vr 4 gen 3 has been damaged and need replacement. Does anyone here know what to replace it with? is it seal or scanspeak or??
Please help me
es347
  • ..I've got my eye on you...which one you say?
Re: damaged tweeter on vr 4 gen 3
« Reply #1 on: 23 Dec 2010, 03:50 pm »
Best give VSA a ring on that one..
Antoine
« Reply #2 on: 23 Dec 2010, 09:46 pm »
Hi, the rear tweeter used in the GenIII HSE is a Vifa H26TG-35-06 dome tweeter (1 inch, 6 Ohm) See: http://www.tymphany.com/files/products/pdf/H26TG-35-06.pdf
It seems to be rebranded to 'Peerless Vline H26TG-35-06' but also looks like it's discontinued so you'll probably have to contact VSA or look for a shop that still has some on the shelves.
ceedee
    • Musical Reality
« Reply #3 on: 23 Dec 2010, 11:57 pm »
Hi Emile,
Are you sure it is the tweeter?
Somtimes it is the wired level adjusteron the back. Try to twist it arround for several moments. If this not succeeds call or mail me for a solution, the VSA guys are very bussy moving the company these days.
Cor
es347
« Reply #4 on: 24 Dec 2010, 03:48 pm »
Moving the company???
JackD201
« Reply #5 on: 25 Dec 2010, 09:27 am »
To a bigger facility :)
emilraaf
« Reply #6 on: 25 Dec 2010, 02:46 pm »
Im sure - because its like someone has put a knife in it. It really need to be replaced. But it seems like no one know with what..
es347
« Reply #7 on: 25 Dec 2010, 04:43 pm »
...uhhh....OK.  I bit too much rum in the eggnog methinks.
penthouse-D
« Reply #8 on: 26 Dec 2010, 10:34 pm »
You can always try www.madisound.com
Antoine
« Reply #9 on: 27 Dec 2010, 01:35 pm »
See post 3 of this topic...
