I have a nominee for the best player under $100.00...
0 Members and 1 Guest are viewing this topic. Read 4294 times.
dBe
    • PI audio group, LLC
at least on my PC based server.  Jury is still out on the MacMini as the main system has been taken over by Christmas decorations!   :roll:
On my office system(s) I have been using either my dedicated mini-ITX that I built for audio or or my Dell XPS running foobar with the AQvox ASIO driver.  The AQvox driver really helped the PC based solution.  That is until Kevin Burke of Mach2 Music recommended that I try Silverjuke.  The difference is really big in a good way.
http://www.silverjuke.net/en/
It is 25 Euros ($38.22 when I bought it) and there is a trial period.
I pretty much like everything about it.  The interface is very good.  It is skinnable, does every format that you can swing a dead duck at, does sample rate conversion, has a good ripper: ie, just about everything one could ask from a player.
If you've tried it, I would like to see your comments, if you haven't I would encourage you to do so.
Of course, YMMV, but I don't think I'm daft.  Well, maybe I'm wrong on that, but I don't think (or hear) so on this one.
Dave
pjchappy
Re: I have a nominee for the best player under $100.00...
« Reply #1 on: 20 Dec 2010, 05:04 pm »
As to what you have compared it to, I'm curious if you have also tried J. River Media Center?
Paul
dBe
« Reply #2 on: 20 Dec 2010, 05:39 pm »
Paul
Paul, here is some of what I've tried:
KM Player w/ReClock (pretty good)
J. River
VLC
MediaMonkey
Winamp
Core 4.11
GOM
Sonbird
and more... until my brain hurt - which really isn't THAT hard  :lol:
Dave
dmccombs
« Reply #3 on: 21 Dec 2010, 05:28 am »
I'll throw Amarra Jr. as my vote in the under $100 category
and
Audirvana in the free (currently) category.
Sorry, I just had to stir the pot a bit...    :icon_twisted:
Darrell
www.mach2music.com
dBe
« Reply #4 on: 21 Dec 2010, 06:57 am »
and
Darrell
www.mach2music.com
You have already done a great job at that !!! :thumb:  You've got Macs covered.
Since I'm still determined (obstinate?) to get a PC to sound as good as possible, this was a good step up in my office/lab/skunkworks.  Besides, I wanted a compatible player for the PC that would do a good job on AIFF files.
It is audio so YMMV
Dave
Vincent Kars
  • The Well Tempered Computer
« Reply #5 on: 23 Dec 2010, 09:07 am »
Had a look at Silverjuke.
I’m afraid I’m not impressed.
For audio it uses BASS libs and the Win audio engine.
Functionality I do think limited.
Free players like MusicBee offers more using the same audio libs.
dBe
« Reply #6 on: 23 Dec 2010, 03:57 pm »
What did you think of the sound, though?
Dave
Vincent Kars
« Reply #7 on: 23 Dec 2010, 04:36 pm »
Nothing special.
Players like MusicBee, AlbumPlayer, Silverjuke all use the same audio drivers:
BASS lib + Win DS.
MusicBee also supports the Win WASAPI interface in exclusive mode.
This bypasses the Win audio engine.
In my case WASAPI  sounds a bit more transparent than DS.
It also allows for all audio to be played at its native sample rate.
http://thewelltemperedcomputer.com/SW/Players/MusicBee/MusicBee_audio.htm
dBe
« Reply #8 on: 23 Dec 2010, 04:45 pm »
Nothing special.
BASS lib + Win DS.
Thanks, I'll give MusicBee a listen.
Merry Christmas.
Dave
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
« Reply #9 on: 11 Aug 2011, 04:01 pm »
and
Darrell
www.mach2music.com
Sorry if this is too out of date... but thought I would ask here.
Curious is if this is same sound quality for redbook, 16 bit,on the junior as the other versions, and the higher cost versions are just more features?
Although, the cache feature would indeed seem to have potential for sound quality improvement aspects, though.
eclein
« Reply #10 on: 11 Aug 2011, 05:06 pm »
I used a whole bunch of different ones and settled on J. River for the look, the flexibility, WASAPI but hey it is audio so its very subjective.
cityjim
« Reply #11 on: 14 Aug 2011, 08:17 pm »
 My WDTVLive Plus is the best 89 bucks I laid out in a long while. Plays nearly any file you can throw at it. FLAC files have a huge soundstage and are sweet and open. Easy to listen to for hours on end. Also plays most all video files. Really an all in one box.
 In a comparison to the squeeze the WDTV Live sounds better hands down. Don't know the hardware inside it but can confirm it makes sweet music.
cityjim
