0 Members and 1 Guest are viewing this topic. Read 7766 times.
If it were me, I'd concentrate on just upgrading the amp for the front 2/3 channels. Maximize the use of funds to get a better 2 channel amp and keep using the other channels of the Onkyo for now. Either the Van Alstine or one of Klaus' Odyssey amps would be a definite improvement IMO.Bryan
Thanks for your input; much appreciated. I hear what you've said but my system is equally music and HT. Therefore, it is important to me to have the same amplification across the front three speakers. That is why, initially, I am looking for at least a three channel amp.
I run my center channel and surrounds off my receiver and it works and sounds perfect to my very discerning ears. So what I'm saying is that I too would be in the camp of getting a solid 2-channel amp for music and let your receiver do the work for the rest.
TJHUB and others:Thoughts on using my tubed integrated for L / R and a SONY AVR for Center, Surrounds and Passive Subs?Realize I will have two separate volume controls, but am willing to accept that.I've been running all channels analog direct into the SONY AVR.Saw your posts, so figured you might have some thoughts.Thanks,David.
A hybrid setup would probably be iffy for HT. I suspect you would be better off using the receiver to power all the speakers. You could then use the tube gear for stereo playback. I've used that configuration in my own home. If you don't want to swap cables on the L/R mains, you could consider using a Niles switch to toggle the L/R between amp sources.
If you mean using your disc player's 5ch analog out, with the front L/R going to your tube integrated and the rest going to the Sony, I see no reason not to.Lin
My primary concern is that the center's sq integration with L/R being close enough / be acceptable for me.
^This guy that I quoted above is a wise man, and I completely agree with his advice. I recommend a used Parasound Halo A21 (just like Mike has). It's a HECK of an amplifier for the price (in a league far above the Classic series amps), but it will break your budget by a few hundred. I prefer it to the recommended Van Alstine amps, but YMMV.
